Fender Mustang lV
Traveler Guitar Travelcaster Deluxe GWT
Boss Katana 100 Head MKII
Pues no que ya habías abierto un hilo? A ver he buscado por ahí tu problema, y en el foro en ingles de Fender hablan un poco sobre ello, te dejo el enlace y dos post especialmente clarificadores.
http://www.fender.com/community/forums/viewtopic.php?f=26&t=49606
-If you don't see the Mustang amp listed in Recording devices, right click in that window where you see microphone and line input as allroypa1 pointed out and check view disabled devices. Then you should see the Mustang amp input. Right click and enable it and it will show in Audacity as a choice in recording devices.
-OK ,... here's the trick. Once you have the mustang plugged into the USB you have to enable it as a recording device in your Control Panel > Hardware and Sound > Sound > Recording(tab) then it shows up when you open Audacity
Fijate sobre todo en la negrita, debería funcionar eso.
