Aqui te dejo las especificaciones de los modelos American Standard lanzados en este año:
Model Name American Standard Telecaster®
Model Number 011-0500-(Color#) and 011-0502-(Color#)
Series American Standard Series
Colors (700) 3-Color Sunburst,
(703)** 2-Color Sunburst, (Maple Fingerboard Only), (Ash Body), **add $100.00 for Special Wood Requirements,
(706) Black,
(712) Candy Cola,
(721)** Natural, (Ash Body),**add $100.00 for Special Wood Requirements,
(738)** Crimson Red Transparent, (Ash Body),**add $100.00 for Special Wood Requirements,
(755) Blizzard Pearl,
(Polyurethane Finish)
Body Alder on:
(706) Black,
(712) Candy Cola,
Ash Body on:
(703)** 2-Color Sunburst, **add $100.00 for Special Wood Requirements,
(721)** Natural, **add $100.00 for Special Wood Requirements,
(738)** Crimson Red Transparent, **add $100.00 for Special Wood Requirements
Neck Maple, Modern “C” Shape,
(Gloss Headstock Face with Satin Urethane Finish on Back of Neck)
Fingerboard Rosewood (p/n 011-0500) or Maple (p/n 011-0502), 9.5” Radius (241mm)
No. of Frets 22 Medium Jumbo Frets
Pickups 2 American Tele® Single-Coil Pickups (Neck & Bridge)
Controls Master Volume, Master Delta Tone™
( “Delta Tone” system includes high output bridge pickup and special No-Load tone control)
Pickup Switching 3-Position Blade:
Position 1. Bridge Pickup
Position 2. Bridge and Neck Pickups
Position 3. Neck Pickup
Bridge American Tele with New American Standard Bent Steel Saddles and Stamped Brass Plate
Machine Heads Fender® Deluxe Staggered Cast/Sealed Tuning Machines
Hardware Chrome
Pickguard 3-Ply Parchment On:
(703) 2-Color Sunburst,
(706) Black,
(712) Candy Cola,
3-Ply Black On:
(721)** Natural,
Scale Length 25.5” (648 mm)
Width at Nut 1.685” (42.8 mm)
Unique Features All New Five-Screw Mounted Brass Bridge Plate for Sonic Stability, Loaded with Improved Bent Steel Saddles with Elongated String Slots, for Increased Resonance and Sustain,
Thinner Undercoat Finish for Improved Body Resonance,
Tinted Neck,
Maple Fingerboard Neck: Satin Finish on Back, Gloss Finish on Front;
Rosewood Fingerboard Neck: Satin Finish on Back, Gloss Finish on Headstock Front with Buffed Fingerboard,
4-Bolt Neck Attachment with Micro-Tilt™ Adjustment,
Bi-Flex Truss Rod System,
Rolled Fretboard Edges,
Staggered Tuning Keys,
H/S/H Pickup Routing,
New Molded Fender/SKB Case with TSA Locks, Glass Reinforced Nylon Trigger Latches, and Form Fitted Plush Interior,
Rolled Fingerboard Edges,
Sharper ‘52 Style Body Radius
Strings Fender Standard Tension ST250L, Nickel Plated Steel,
Gauges: (.009, .011, .016, .024, .032, .042),
p/n 073-0250-203
Accessories Fender/SKB® Case, Cable, Strap, Polishing Cloth
Case High-Tech, Molded Rectangular SKB® Case
Introduced 1/2008
Model Name American Standard Stratocaster®
Model Number 011-0400-(Color #) and 011-0402-(Color #)
(705) Olympic White,
(706) Black,
(712) Candy Cola,
(747)** Sienna Sunburst, (Ash Body),**add $100.00 for Special Wood Requirements,
(769) Charcoal Frost Metallic,
Body Alder on:
(706) Black,
(712) Candy Cola,
Ash on:
(747)** Sienna Sunburst, **add $100.00 for Special Wood Requirements,
Fingerboard Rosewood (p/n 011-0400) or Maple (p/n 011-0402), 9.5” Radius (241mm)
Pickups 3 American Strat® Single-Coil Pickups
Tone 1. (Neck Pickup),
Tone 2. Delta Tone™
(“Delta Tone” system includes high output bridge pickup and special No-Load tone control for Middle and Bridge Pickups)
Pickup Switching 5-Position Blade:
Position 2. Bridge and Middle Pickup
Position 3. Middle Pickup
Position 4. Middle and Neck Pickup
Position 5. Neck Pickup
Bridge 2-Point Synchronized Tremolo with New American Standard Bent Steel Saddles
Hardware Chrome
Unique Features New Bent Steel Saddles with Elongated String Slots,
Copper Infused High Mass 100% Metal Bridge Block,
Tinted Neck,
Parchment Knobs and Pickup Covers,
Strings Fender® Standard Tension™ Bullet ST3250L, Nickel Plated Steel, (.009 to .042), p/n 073-3250-203
Introduced 1/2008
Unos ejemplos:
Telecaster:
[URL de YouTube no válida]
Stratocaster:
Aunque si realmente queres saber la diferencia, nada como ir a una tienda de instrumentos que tenga ambos modelos y probarlos con un ismo amplificador.
