http://www.guitardaterproject.org/gibson.aspx
y me tira; Your guitar may have been made prior to 1977, in that case you may need to use the Vintage Panel, simply select all the options that best describe your guitar. If you are still having difficulties please contact the webmaster. si alguien me puede dar una mano se lo agradesco..
el numero de serie comienza( no es el numero verdadero) ej: f4551566 una letra y 7 numeros no dice en ningun lado de donde es...me fije aca
