3ª llave allen stratocaster deluxe.Para qué es?
-10%Epiphone Les Paul 59 Tobacco Burst
-8%Fender Tone Master Deluxe Reverb
-13%PRS SE Silver Sky Piano Black
SHIMMING/MICRO-TILT™ ADJUSTMENT
Shimming is a procedure used to adjust the pitch of the neck in relation to the body. A shim is placed in the neck pocket, underneath the butt end of the neck. On many American series guitars, a Micro-Tilt adjustment is offered. It replaces the need for a shim by using a hex screw against a plate installed in the butt end of the neck. The need to adjust the pitch (raising the butt end of the neck in the pocket, thereby pitching the neck back) of the neck occurs in situations where the string height is high and the action adjustment is as low as the adjustment will allow.
To properly shim a neck, the neck must be removed from the neck pocket of the body. A shim approximately 1/4" (6.4 mm) wide by 1 3/4" (44.5 mm) long by .010" (0.25 mm) thick will allow you to raise the action approximately 1/32" (0.8 mm). For guitars with the Micro-Tilt adjustment, loosen the two neck screws on both sides of the adjustment access hole on the neckplate by at least four full turns. Tightening the hex adjustment screw with an 1/8" hex wrench approximately 1/4 turn will allow you to raise the action approximately 1/32". Re-tighten the neck screws when the adjustment is complete. The pitch of the neck on your guitar has been preset at the factory and in most cases will not need to be adjusted.
Se algo de ingles... Pero aun asi no se bien para qué sirve ni cómo se ajusta. Sé ajustar el alma. Se supone que el alma ajusta lo curvo que esta el mástil en sí y esto ajusta la inclinaciondel mastil con el cuerpo?? osea que se podria poner o mas curpado o mas tenso aun??? No me entero mucho a ver..
