Hola a Todos X) ... Estoy Pensando en adquirir una de estas dos Guitarras? alguien que pueda contar sus experiencias con ellas ? , toco metal pero lo que busco con esta guitarra es tocar algo mas suave. un funk, jazz, un rock suave.. Gracias de antemano
bueno aqui les dejo unas imagenes y sus especificaciones
ESP LTD TE-202 vienen en Maple y en Rosewood ( 350 $)
SPECIFICATIONS
Bolt-On Construction
25.5" Scale
Alder Body
Maple Neck
Maple Fingerboard / Rosewood Fingerboard
42mm Standard Nut
Thin U Neck Contour
22 XJ Frets
Nickel Hardware
ESP Tuners
Traditional Flat-Mount Bridge
ESP LTS-120 (B) / LH-150 (N) p.u.
Finish: Distressed BLK
CONTROLS
3-Way Switch
Master Volume
Master Tone
Fender Blacktop(TM) Telecaster ( 500 $ )
Body
Body Material: Alder Body Shape: Telecaster®
Neck
Number of Frets: 22
Fret Size: Medium Jumbo
Position Inlays: Black Dots on Maple, White Dots on Rosewood
Fingerboard Radius: 9.5" (24.1 cm)
Fretboard: Rosewood or Maple
Neck Material: Maple
Neck Finish: Gloss Urethane
Nut Width: 1.650” (42 mm)
Scale Length: 25.5" (64.8 cm)
Neck Plate: Vintage Style 4 Bolt
Truss Rod Nut: 3/16" Hex Adjustment
Electronics
Pickup Configuration: H/H
Bridge Pickup: Hot Vintage Alnico Humbucking Pickup (Bridge)
Neck Pickup: Hot Vintage Alnico Neck Humbucking Pickup with Nickel Cover
Pickup Switching: 3-Position Blade: Position 1. Bridge Pickup, Position 2. Bridge and Neck Pickups, Position 3. Neck Pickup
Controls: Master Volume, Master Tone
Hardware
Hardware Finish: Nickel/Chrome
Bridge: Strings-Through-Body Hardtail Bridge With 6 Cast Saddles
String Nut: Synthetic Bone
Switch Tips: Black Switch Tip
SPECIFICATIONS
25.5" Scale
Alder Body
Maple Neck
42mm Standard Nut
Thin U Neck Contour
22 XJ Frets
Nickel Hardware
ESP Tuners
CONTROLS
3-Way Switch
Master Volume
Master Tone
Body
Neck
Number of Frets: 22
Electronics
Hardware
