quuisiera qe me ayudaran a escojer entre esos dos modelos
son para tocar metal y me gustaron porqe traen los emgs activos
bueno son estas dos
Jackson DKMG Dinky Electric Guitar with EMGs
* Body Style: Dinky
* Body: Alder
* Neck:
* Neck Type: Bolt-on rock maple with scarf joint headstock
* Neck binding: Ivoroid binding on neck and headstock
* Neck dimensions: 1st Fret: .735", 12th Fret: .810"
* Fingerboard: Rosewood
* Fingerboard radius: 12" to 16" compound radius/304.8mm to 406.4mm
* Scale length: 25.5"/648mm
* Number of frets: 24
* Fret Size: Jumbo frets
* Nut Width: 1.6875"/43mm
* Inlays: MOTO shark
* Electronics:
* Bridge Pickup: EMG-81
* Neck Pickup: EMG-85
* Pickup Switching:
* 3-position blade:
* Position 1. Bridge pickup
* Position 2. Middle pickup
* Position 3. Neck pickup
* Controls: Master volume, master tone
* Hardware:
* Hardware: Black
* Bridge: Floyd Rose Licensed Jackson Low Profile JT580 LP double-locking 2-point tremolo
* Tuners: Sealed die-cast tuners
* Strings: NPS, Gauges: .009, .011, .016, .024, .032, .042
* Case: Deluxe Jackson molded case by SKB
en total son 800 dlls con case incluido
y la otra es
ESP LTD MH-1000 FR With EMG Pickups Features:
* Set-thru neck
* 25.5" scale
* Mahogany body
* Quilted maple top
* (See-Thru Blue and See-Thru Black)
* Maple neck
* Rosewood fingerboard
* Locking nut
* 42mm neck width
* Thin U neck contour
* 24 XJ frets
* Black nickel hardware
* Grover tuners
* Floyd Rose 1000 Series bridge
* EMG-81(bridge)/EMG-85 (neck) Active humbuckers
en 800 dlls tan bien, sin el case
por mi compraria la primera pero me estan diciendo que el floyd de la jackson es low profile i a la larga no te conviene porqe se salen las cuerdas
y la esp trae el floyd rose 1000 series qe es igual al original solo que hecho en korea
alguien me podria despejar de esta duda??
y ustedes cual comprarian??
jaja i una B.C Rich ASM Pro??
