Movido de "Ayuda para eleccion de guitarra y bajo" a "Guitarras eléctricas, acústicas, clásicas y bajos" (Julio)
¿Qué guitars son?
Boss Katana 100 Head MKII
Traveler Guitar Travelcaster Deluxe GWT
Adrian vanderberg fue endorser de Fernandes, no se si en aquella epoca.
En el tour WS '87 uso 3 Peavey VTM120's,
Guitarras ESP, Fernandes y ocasionalmente Peavey Vandenberg .
Imagen no disponible
En the Slip of the Tongue uso Vandenberg guitars y como amps amps... Peavey Rockmaster & Classic series
Tambien 2 Soldano's custom
Vandenberg 1
Body: basswood
Neck: bolt-on, maple
Headstock: reversed
Fingerboard: rosewood, 350R, sharkfin inlay
Frets: 24
Scale length: 25.50"
Pickups: 3, HSS configuration
Controls: 1 V, 1 T(humbuckercoiltap), 5 way PU SW
Bridge: black Floyd Rose style string lock and tremolo
Colours: Custom graphic design(large black squares on white background, accentuated with 5 smaller pink squares)
Vandenberg 2 (FR-120AV)
Body: Sen(Japanese ash)
Neck: neck thru, maple/walnut laminate
Headstock: reversed
Fingerboard: ebony, 350R, sharkfin inlay
Frets: 24
Pickups: 3, active FGI-SH, HSS configuration
Controls: 1 V, 1 T, 5 way PU SW, neck/bridge PU mix SW
Colours: Custom graphic design(large black squares on white background, accentuated with 5 smaller purple squares)
Vandenberg 3 There is a third Vandenberg, but it's Japan only. Specification and price would place it somewhere between the 1 and 2 model.
Peavey
Vandenberg Signature 1
Body: poplar, arched top and extra top horn cutaway
Neck: bolt-on, 2 piece laminated maple
Headstock: reversed
Fingerboard: ebony, pearl dots position markers
Frets: 24
Scale length: 24 3/4"
Pickups: 2 medium output(HB bridge, SC neck), angled 4º
Controls: 2 V, 3 way PU SW
Bridge: black Kahler 2700 tremolo(recessed) and string lock
Colours: Gloss Black, Sunfire Red and Rock-it Pink
Vandenberg Signature 2
Body: poplar, low fiddle-cut less deep as model 1
Neck: bolt-on, 2 piece laminated maple, thicker as model 1
Headstock: reversed
Fingerboard: ebony, pearl dot inlay
Frets: 24
Bridge: black Kahler 2730 tremolo(recessed) and string lock
Colours: Gloss Black, Sunfire Red, Rock-it Pink, and metallic Pearl White, '62 Blue, Laser Red and Raspberry Pearl
Vandenberg Signature 3
The last of the signatures. Produced after the quilt top. Same as previous signature models except for the tilted neck joint. New Peavey logo printed on the regular black Peavey headstock in white, and "Vandenberg" with very small lettering. and newer Peavey/Kahler "Floyd-clone" tremolo.
The Vandenberg Custom
Body: 1 piece mahogany, arched top
Neck: neck-through, 1 piece maple
Headstock: reversed
Fingerboard: ebony/maple, pearl stripes inlay
Frets: 24
Pickups: 2 high output(HB bridge, SC neck), angled 4º
Controls: 2 V(bridge is push/pull), 3 way PU SW
Bridge: Kahler 2730 tremolo(recessed) and string lock
Colours: Gloss Black, Sunfire Red, Rock-it Pink, and metallic Pearl White, '62 Blue, Laser Red and Raspberry Pearl with body, headstock and neck in the same colour
The Vandenberg Custom Quilt Top
Body: 1 piece mahogany back, quilt maple top
Neck: neck-through, 1 piece mahogany
Headstock: reversed
Fingerboard: ebony, cream binding, pearl stripes inlay
Frets: 24
Pickups: 2 HB (bridge and neck)
Controls: 2 V, 3 way PU SW, 2-way mini SW
Bridge: gold Kahler 2730 tremolo(recessed) and string lock
Colours: Transparent Honey Sunburst, Transparent Purple and Transparent Pink
The Vandenberg Puzzle
Neck: neck-through, two piece laminated maple
Headstock: reversed
Fingerboard: ebony, domino-dots inlay
Frets: 24
Pickups: 1 HB(bridge) and 1 SC(neck), angled 4º
Controls: 2 V, 3 way PU SW, coil tap mini SW
Colours: White Puzzle graphic on black, and very rare Black Puzzle graphic on white!
Vandenberg 1
Body: basswood
Headstock: reversed
Frets: 24
Headstock: reversed
Frets: 24
Peavey
Headstock: reversed
Frets: 24
Headstock: reversed
Frets: 24
Headstock: reversed
Frets: 24
Headstock: reversed
Frets: 24
Headstock: reversed
Frets: 24
