Pues si amigos, después de ver como los que tocan guitarras en Drag-on-fuzz, han conseguido sus guitarras signature, no es de extrañar que alguien como él tenga unos amplis personalizados.
Encima vienen con sus estupendos sonidos de gran tono y brillo.
Edición limitada con los preamps:
Imagen no disponibleThe exclusive Kirk Hammett stack includes a 4x12 cabinet, 100-watt power-tube head and signature MTS modules to enable musicians everywhere to attain Kirk's legendary tones. The custom gear arrives painted in a black-burst color scheme complete with polyurethane finish. The end result is a visually stunning half stack that fully captures the defining sounds of Metallica's legendary guitarist.
The Limited Edition Half Stack complements the full line of Kirk Hammett Signature Series products, which includes MTS modules, all-tube heads, as well as power tubes, all to enable musicians everywhere to attain his flawless sound. Kirk worked intimately with Randall to ensure that all aspects of the products, from the look and feel of the heads and amps to the distinct tones of each MTS module, were up to the standards of rock's legendary guitarist.
Additional Limited Edition Kirk Hammett Half Stack Features:
Pre-loaded with KH1, KH2, and KH3 MTS modules:
* KH1 - Classic clean tone
* KH2 - Signature rhythm tone
* KH3 - Legendary high-gain rhythm
Easily replace power tubes with user-friendly power-tube bias MIDI In/Thru for easy switching between pre-amp modules Master volume, presence, and density controls Parallel loop with front panel mix control Series loop.
The Kirk Hammett Limited Edition Half Stack retails for $9,999.90 (solo?)and is available at exclusive Randall dealers.
Edición normal:
RM100KH
PREAMP CHANNELS: 3 Modular Channels KH1, KH2 & KH3 Preamps
MASTER CONTROLS: Volume • Presense • Density
POWER AMP: All Tube • 4 x JJ6L6GC
POWER OUTPUT: 100 Watts
FEATURES: Series EFX Loop, Parallel EFX Loop, Front Panel Mix Control, Midi in/Thru, Rear Panel Tube Bias Section, World Voltage Selector RF3
MIDI Footswitch Included: RS412KHX & RS412KH100
POWER HANDLING: 280 Watts RMS
IMPEDANCE: 4/16Ω Mono Inputs, 8Ω Stereo Inputs
FEATURES: 3/4" Void Free Birch Plywood Straight Front, "Mic Eliminator" XLR Direct Outputs
SPEAKERS: (RS412KHX) 2 x 12" Celestion G12T-75, 2 x 12" Celestion Vintage 30
SPEAKERS: (RS412KH100) 4 x 12" Custom Celestion G12H-100s
También tiene preamps:![:si: :si:](https://statics2.soniccdn.com/images/smilies/yes4.gif)
Randall KH1 MTS Module
Based on Kirk¹s classic clean tones, the voicing of this preamp is based on various clean amps that Kirk has used through out his illustrious career. A great clean tone for any style, but tailored for any rock and metal clean because it stays clean at higher volumes even with active pickups.
Randall KH2 MTS Module
Based on Kirk¹s signature rhythm tone, the KH2 instantly becomes a classic because of its extreme wide-range of tones. This mid to high gain preamp is perfect for any classic rock and metal tone and for that early Metallica rhythm tone.
Randall KH3 MTS Module
Based on Kirk¹s legendary high gain rhythm tone, this preamp takes the KH2 to a higher level of gain and sustain. Utilizing the same tone circuit as the KH2, the KH3 is tailored more for the modern rock and metal guitarist who demands a high level of gain.
Al final igual es bueno y todo.
En Thomann:
RANDALL RM-100KH - Thomann Cyberstore Español
RANDALL RS412KHX - Thomann Cyberstore Español
RANDALL RS412KH100 - Thomann Cyberstore Español
2290 + 954 + 954= 4198 € <<<<< 9999$ nos la quieren meter doblada?
Edición normal:
RM100KH
En Thomann:
