Bueno dias tengo algunas dudas sobre esta guitarra. http://www.jacksonguitars.com/products/search.php?partno=2911001803
Soy zurdo por lo que no hay mucho mercado de guitarras y esta se ajusta a mi presuspuesto pero me gustaria saber que tal es la calidad del puente flotante que tiene, ya que he leido mucho que si el puente no es muy bueno se desafina facilmente (Nunca he tenido guitarra con puente flotante) esa es mi mayor duda entonces no se que hacer
Aqui las caracteristicas
products specs general
Model Name: DK2L Dinky™
Series: Pro Series
Color / MSRP* / Part # :
Black
$0.00
291-1001-803
products specs body
Body: Alder
Body Shape: Dinky™
products specs neck
Number of Frets: 24
Fret Size: Jumbo Frets
Position Inlays: MOTO Shark Fin Position Inlays
Fretboard Radius: 12” to 16” Compound Radius (304.8 mm to 406.4 mm)
Fretboard: Rosewood
Neck Material: Bolt-On Maple
Nut Width: 1.6875" (43 mm)
Scale Length: 25.5" (64.8 cm)
Headstock: Reverse Headstock
Neck Plate: Standard 4 Bolt
products specs electronics
Pickup Configuration: H/S/S
Bridge Pickup: Seymour Duncan® JB™ TB4 Humbucking Bridge Pickup - Direct Mount
Middle Pickup: Seymour Duncan® STK-1 Single-Coil Middle Pickup
Neck Pickup: Seymour Duncan® STK-T1 Single-Coil Neck Pickup
Pickup Switching: 5-Position Blade: Position 1. Bridge Pickup, Position 2. Bridge and Middle Pickup, Position 3. Middle Pickup, Position 4. Middle and Neck Pickup, Position 5. Neck Pickup
Controls: Master Volume, Master Tone
products specs hardware
Hardware: Black
Bridge: Floyd Rose® Licensed Jackson® Low Profile JT580 LP Double Locking 2-Point Tremolo
Tuning Machines: Die-Cast Tuners
String Nut: Jackson® Floyd Rose® Nut
Switch Tip: Black Switch Tip
Tremolo Arm/Handle: Licensed Floyd Rose® Collared Tremolo Arm
products specs miscellaneous
Strings: NPS, Gauges: .009, .011, .016, .024, .032, .042
products specs accessories
Case/Gig Bag: Deluxe Jackson® Molded Case
Included Accessories: Deluxe Jackson® Molded Case
Control Knobs: Black Dome Style
Series: Pro Series
Black
$0.00
291-1001-803
products specs body
Body: Alder
Body Shape: Dinky™
products specs neck
Number of Frets: 24
Fretboard: Rosewood
Hardware: Black
