Bueno, como hace tiempo que respondí he vuelto a escuchar el vídeo, y lo que dice el hombre en el minuto 0:39 es "you're gonna learn some different techniques such as
sweep picking, there's gonna be some
alternate picking as well, there's gonna be some
string skkiping which is something he does quite a lot"..."And then, y'know, there's quite a lot, I'm gonna give you some
arpeggios in there, you know, again in the solo of Synyster Gates"..."Danny Elfmond feels
X that some of the chord progressions he uses with his
arpeggios. So I'll try and play a little bit of that, as well as his use of some
chromaticisms and a set of alternate picking. So there's quite a lot of techniques..."
Te he subrayado las técnicas que utiliza para tocar este solo. No dice nada de la escala en que se basa todo pero te lo digo ahora; es Dm armónica en su modo dórico. D E F G# A B C. 1 2 b3
#4 5 6 b7.
P.D. La X en rojo es una palabra que no vocaliza mucho y no la entiendo.
