Fender 50 aniversario 2004, ¿cómo autentificar?
pacovilches
por el 01/04/2019
Hola, Aporto esta informacion sobre los modelos 50th aniversario de Fender de 2004, donde explica la diferencia entre estos modelos y las Fender construidas en 2004, en las que aparece la chapa conmemorativa, pero que realmente son modelos Standards de Fender sin las caracteristicas de las 50th aniversario.
Since 2004, there have been increasing numbers of standard Fender American Deluxe and American Series Stratocasters being passed off as premium '50th Anniversary Limited Edition' models. The year 2004 was the 50th anniversary of the Fender Stratocaster (not to be confused with the 50th and 60th anniversaries of the Fender Company in 1996 and 2006, which also saw the issue of limited edition commemorative models). To celebrate this anniversary Fender produced four limited edition commemorative 50th Anniversary Stratocaster models distinct from the the standard production line models. These were the Custom Shop 1954 replica, the 50th Anniversary American Deluxe, the 50th Anniversary American Series, and the 50th Anniversary Golden Stratocaster (the last from their Mexican factory). This guide is essentially concerned with the 50th American Deluxe and 50th American Series Stratocasters.
The 50th Anniversary American Deluxe commemorative Stratocaster has a number of features that distinguish it from the standard production line American Deluxe Stratocaster. It was only produced in two-colour sunburst (as opposed to three-colour sunburst and other colours for the standard production line models) with maple neck/fretboard and single-ply parchment pickguard. It was fitted with goldplated hardware, and came in a special oblong deluxe tweed case with a '50th Anniversary' logo embossed in the lining (instead of the moulded cases that the standard production line models came with).
The 50th Anniversary American Series commemorative Stratocaster has even more features that distinguish it from the standard production line American Series Stratocaster. These had ash bodies (usually characterised by distinctive grain patterns which made them particularly attractive), as opposed to alder used in the standard production line models, single-ply parchment pickguards (unlike the 3-ply ones on the standard production models) and only came in two-colour sunburst with maple neck/fretboard. These also came in the special oblong deluxe tweed case. Less obvious, and without a doubt the feature that makes the 50th Anniversary American Series so desirable, are the special Custom Shop '54 pickups they were fitted with (these pickups are not the same as the after-market Custom Shop 54 pickups available in shops, and cannot be obtained any where else, unless they have been removed from a 50th American Series) .
Fender regrettably made it easy for scammers as all standard production line Stratocasters produced in the anniversary year of 2004 were fitted with commemorative neck plates. However, these alone do not make the guitars '50th Anniversary' models. Apart from the neckplate, these standard production line guitars are no different from those produced in 2003 or 2005. Many sellers now try to pass off standard production line American Deluxe and American Series Stratocasters as 'limited edition 50th Anniversary models' merely on the strength of the commemorative neck plates.
What to look for when buying a 50th Anniversary American Deluxe Stratocaster:-
Colour - MUST be two-colour sunburst, no other colour is genuine.
Neck/fretboard - MUST be maple, NOT rosewood.
Hardware - MUST be gold.
Neck plate - 50th Anniversary etched plate.
Pickguard - Single-ply parchment, NOT 3-ply white/black/white or any other colour, with laser-etched logo.
Pickups - SCNs with S1 switch system, in 3 single coils configuration only, NOT HSS.
Case - oblong tweed case with crushed gold lining, NOT black moulded case.
Fender inspection card - this should state the 'part' or model number 0112004803 together with the serial number of the guitar (standard production line models will show different 'part numbers').
What to look for when buying a 50th Anniversary American Series Stratocaster:-
Body - MUST be ash, usually identifiable by prominant grain patterns.
Pickguard - Single-ply 11-hole parchment, NOT 3-ply white/black/white or any other colour (the 50th American Series is quite possibly the only Fender Stratocaster model with an 11-hole single-ply parchment pickguard. All other parchment pickguards are either 11-hole 3-ply or 8-hole single-ply).
Pickups - Custom Shop '54s in 3 single coils configuration only, NOT HSS. Apart from the unbeveled pole pieces, these are difficult to distinguish by sight alone. If you have the opportunity, try out the guitar plugged into an amplifier, and, if possible compare with a standard Stratocaster, and you should be able to recognise a superior tone. However, tone is subjective, and a better way to distinguish the authenticity of the guitar by its pickups is as follows. The production line American Series models come with a hum-cancelling reverse wound / reverse polarity middle pickup, which means that positions 2 and 4 on the 5-way switch, which combine the bridge and middle pickups, and neck and middle pickups, are relatively hum-free. The genuine 50th Anniversary American Series on the other hand does not have a reverse wound / reverse polarity middle pickup, and positions 2 and 4 therefore hum as much as the other positions.
Fender inspection card - this should state the 'part' or model number 0102004-803 (10 denotes American Series, 2004 denotes 50th Anniversary model, 8 denotes a deluxe tweed case, and 03 denotes a two-tone sunburst finish) together with the serial number of the guitar (standard production line models will have a 'part' or model number 0117402-7XX).
For those wishing to acquire one of these not only as collectors' items but also as outstanding musical instruments, it is the 50th American Series they should go for. Apart from the gold plating and purely cosmetic features, the 50th American Deluxe is no different from, or better than, the production model American Deluxes, and, with the SCN pickups, tend to have a more 'modern' than vintage sound. The 50th American Series, on the other hand, has an outsanding 'vintage' tone, and is widely acclaimed to be one of the best non-Custom Shop guitars ever produced by Fender. It is probably not surprising that there are now considerably more used 50th Deluxes for sale than 50th American Series', as owners have become wise to what they have and are more inclined to keep the latter. Accordingly, the 50th American Series' are becoming increasingly rare and rapidly rising in value.
  • -45%
    48 €
    Harley Benton SC‑Custom III Active VBK
    298 €
    Daddario NYXL45105 Bass Set
    24,9 €
fran prieto
por el 01/04/2019
La foto que has puesto es de la deluxe 50th anniversay.Oficial 100%100
NACHO
por el 01/04/2019
Está genial compañero.
Solo una sugerencia: este foro es de hispanohablantes y aunque yo por ejemplo no tengo ningún problema en leer lo escrito en inglés, (de hecho me paso toda la jornada laboral en ese idioma), mucha gente no podrá disfrutar de este artículo por el hecho de estar en una lengua que no hablan o no lo hacen de forma fluida.
Al publicar este tipo de artículos deberíamos hacerlo traducidos para que el alcance del mismo sea mayor.
Solo es mi opinión.
Edit: de hecho el primer mensaje me da la razón.
Creo, que el compañero piensa que estás preguntando si la de la foto es original, cuando lo que ocurre, es que lo que has publicado es una guia de como identificar el modelo.
fran prieto
por el 01/04/2019
#3
Ok gracias.
Yo tengo la american series 50th y es la única fender que no he vendido.Un guitarrón
pacovilches
por el 01/04/2019
TRADUCTOR
Desde 2004, ha habido un número cada vez mayor de modelos estándar de Fender American Deluxe y American Series Stratocasters que han sido aprobados como modelos premium '50th Anniversary Limited Edition'. El año 2004 fue el 50 aniversario de la Fender Stratocaster (no debe confundirse con los 50 y 60 años de la Fender Company en 1996 y 2006, que también vio el tema de los modelos conmemorativos de edición limitada). Para celebrar este aniversario, Fender produjo cuatro modelos Stratocaster conmemorativos del 50 aniversario de la edición limitada, distintos de los modelos de la línea de producción estándar. Estas fueron la réplica de Custom Shop 1954, el 50 Aniversario de American Deluxe, la Serie Americana de 50 Aniversario y la Stratocaster Dorada de Aniversario 50 (la última de su fábrica mexicana). Esta guía está esencialmente relacionada con la 50ª American Deluxe y la 50ª American Series Stratocasters.
La Stratocaster conmemorativa del 50 aniversario de American Deluxe tiene una serie de características que la distinguen de la línea de producción estándar American Deluxe Stratocaster. Solo se produjo en rayos solares de dos colores (en lugar de rayos solares de tres colores y otros colores para los modelos de la línea de producción estándar) con mástil / diapasón de arce y golpeador de pergamino de una sola capa. Fue equipado con herrajes enchapados en oro, y vino en un estuche de tweed de lujo oblongo especial con un logotipo de '50 aniversario' en relieve en el forro (en lugar de los estuches moldeados que vienen con los modelos de la línea de producción estándar).
La Stratocaster conmemorativa de la Serie Americana del 50 aniversario tiene aún más características que la distinguen de la línea de producción estándar de la Serie Americana Stratocaster. Éstos tenían cuerpos de ceniza (generalmente caracterizados por patrones distintivos de grano que los hacían particularmente atractivos), a diferencia del aliso utilizado en los modelos de línea de producción estándar, golpeadores de pergamino de una sola capa (a diferencia de los de 3 capas en los modelos de producción estándar) y solo vino en dos colores sunburst con mástil de arce / diapasón. Estos también vinieron en el caso especial de tweed de lujo oblonga. Menos obvias, y sin lugar a dudas la característica que hace que la Serie Americana del 50 Aniversario sea tan deseable, son las pastillas especiales Custom Shop '54 con las que fueron equipadas (estas pastillas no son las mismas que las postventa Custom Shop 54 disponibles en las tiendas) , y no se puede obtener en ningún otro lugar, a menos que hayan sido eliminados de una 50.ª Serie Americana).
Lamentablemente, Fender lo hizo fácil para los estafadores, ya que todas las líneas de producción estándar producidas por Stratocasters en el año de aniversario de 2004 estaban equipadas con placas conmemorativas para el cuello. Sin embargo, estos solo no hacen los modelos de '50 aniversario' de las guitarras. Aparte de la placa del mástil, estas guitarras de línea de producción estándar no son diferentes de las producidas en 2003 o 2005. Muchos vendedores ahora intentan pasar la línea de producción estándar American Deluxe y American Series Stratocasters como "modelos de edición limitada del 50 aniversario" simplemente por la fuerza de Las placas conmemorativas del cuello.
Qué buscar al comprar una Stratocaster American Deluxe de 50 aniversario: -
Color: DEBE ser un resplandor solar de dos colores, ningún otro color es genuino.
Cuello / diapasón: DEBE ser de arce, NO de palo de rosa.
Hardware - DEBE ser de oro.
Plato cuello - Plato grabado 50 aniversario.
Pickguard: pergamino de una sola capa, NO 3 capas de blanco / negro / blanco o cualquier otro color, con logotipo grabado con láser.
Recolecciones: SCN con sistema de interruptor S1, solo en configuración de 3 bobinas, NO HSS.
Caja: caja de tweed oblongo con forro de oro triturado, NO caja moldeada en negro.
Tarjeta de inspección del guardabarros: debe indicar la 'parte' o el número de modelo 0112004803 junto con el número de serie de la guitarra (los modelos de línea de producción estándar mostrarán 'números de pieza' diferentes).
Qué buscar al comprar una Stratocaster American Series de 50 aniversario: -
Cuerpo: DEBE ser ceniza, generalmente identificable por los patrones de grano prominentes.
Pickguard: pergamino de 11 agujeros de una sola capa, NO 3 capas de blanco / negro / blanco o cualquier otro color (la serie American número 50 es posiblemente el único modelo de Fender Stratocaster con un protector de pergamino de una sola capa de 11 hoyos. Todos los demás pergaminos los golpeadores son de 11 agujeros de 3 capas o de 8 agujeros de una sola capa).
Recolecciones - Custom Shop '54s solo en configuración de 3 bobinas, NO HSS. Aparte de las piezas polares sin biselar, estas son difíciles de distinguir solo con la vista. Si tiene la oportunidad, pruebe la guitarra enchufada a un amplificador y, si es posible, compare con una Stratocaster estándar, y debería poder reconocer un tono superior. Sin embargo, el tono es subjetivo, y una mejor manera de distinguir la autenticidad de la guitarra por sus pastillas es la siguiente. La línea de producción de los modelos de la Serie Americana viene con una pastilla intermedia de polarización inversa / polarización con cancelación de zumbido, lo que significa que las posiciones 2 y 4 en el interruptor de 5 vías, que combinan las pastillas puente y media, y las pastillas central y central, son relativamente libre de zumbidos La serie estadounidense 50th Anniversary genuina, por otro lado, no tiene una posición central de polarización inversa / polaridad inversa, y las posiciones 2 y 4 por lo tanto zumban tanto como las otras posiciones.
Tarjeta de inspección del guardabarros: debe indicar la 'parte' o el número de modelo 0102004-803 (10 denota la serie estadounidense, 2004 denota el modelo del 50 aniversario, 8 denota una caja de lujo de tweed y 03 denota un acabado de rayos de sol de dos tonos) junto con la serie Número de la guitarra (los modelos de línea de producción estándar tendrán una 'parte' o número de modelo 0117402-7XX)
Para aquellos que deseen adquirir uno de estos, no solo como artículos de colección, sino también como instrumentos musicales sobresalientes, es la 50ª serie estadounidense a la que deberían ir. Aparte del chapado en oro y las características puramente cosméticas, el 50th American Deluxe no es diferente o mejor que el modelo de producción American Deluxes y, con las pastillas SCN, tienden a tener un sonido más "moderno" que el de la vendimia. La 50.ª serie estadounidense, por otro lado, tiene un tono "vintage" extraordinario, y es ampliamente aclamado como una de las mejores guitarras no Custom Shop jamás producidas por Fender. Probablemente no sea sorprendente que ahora haya 50º Deluxes en venta más usados ​​que la 50.ª serie estadounidense, ya que los propietarios se han dado cuenta de lo que tienen y están más dispuestos a conservar esta última. En consecuencia, las 50.as Series americanas se están volviendo cada vez más raras y están aumentando rápidamente su valor.
kuervo
por el 02/04/2019
Yo tengo la deluxe 50th aniversario y estoy muy contento con la guitarra, he leido por foros especializados que esta guitarra es simplemente una deluxe normal con herrajes dorados y un estuche bonito
joemart
por el 03/03/2020
Ayuda;
Hola yo estoy por comprar una Strato 50 aniversario USA-2004-2005 pero trae todo el hardware en color plateado o gris y el diapason es de palo de rosa, veo que no coincide con las especificaciones marcadas aquí, pero en youtube vi unas igualitas a la que me venden y supuestamente son 50 aniversario USA-2004-2005 , que me recomiendan? es original con estas diferencias?
kuervo
por el 03/03/2020
Una cosa son las deluxe de serie que sacaron en el 2004 y que todas las de ese año iban con la plaquita de detras que pone 50th aniversary y otra las deluxe edicion limitada que van en herrajes dorados y un estuche de lujo tweed que son mejores pues la madera esta mejor seleccionada y la pintura es mejor y viene con estuche de lujo. De las limited edition no sacaron muchas y son guitarrones, yo tengo una.
Osquiner
por el 13/10/2020
Aquí dejo la mía que he adquirido recientemente, es una auténtica obra de arte.
Lucas Rodicio
por el 30/11/2020
Buenas a tod@s los del foro,
Quería preguntar si la información que compartís de verificación de la guitarra si es fiable al 100x100 y de donde está extraído.
Gracias por la información 📃
Apodo
por el 30/11/2020
Me temo que de tus 2 afirmaciones, la primera es la correcta. Lo de que la madera está mejor seleccionada y la pintura es mejor ¿de qué fuente sale?
En el 2004 sacaron, si la memoria no me falla, 3 modelos conmemorativos: una Custom Shop (que sería la realmente conmemorativa jeje) una American Standard y una American Deluxe. Las 3 compartían como característica "especial" el sunburst en 2 tonos sobre cuerpos de fresno y el estuche. La American Standard estaba además por encima de la serie normal también por las pastillas, que eran Fender Custom Shop. La American Deluxe como diferencia del resto de su serie además del sunburst de 2 tonos y el estuche, tenía únicamente los herrajes dorados y una pegatina, grabado o lo que fuese 50th en el golpeador.
Cuestión aparte es que el resto de guitarras ese año llevasen el grabado conmemorativo del 50th en la placa de unión cuerpo/mástil, pero eran guitarras sin ninguna otra particularidad o "mejora".
V
por el 06/12/2020
Hola, soi nuevo aquí me gustaría saber si es auténtica esta guitarra Fender Stratocaster 50 aniversary american legend. Puedo adjuntar más fotos
