Mira:
JS32T
Body: Basswood
Body Shape: Rhoads
Neck Shape: Speed Neck
Number of Frets: 24
Fret Size: Jumbo
Position Inlays: Pearloid Sharkfin
Fretboard Radius: 12" to 16" Compound Radius (304.8 mm to 406.4 mm)
Headstock Binding: White
Fretboard: Rosewood
Neck Material: 1-Piece Bolt-On Maple Speed Neck with Graphite Reinforcement and Scarf Joint
Neck Finish: Satin
Nut Width: 1.6875" (42.8 mm)
Scale Length: 25.5" (648 mm)
Headstock: Jackson Pointed 6-In-Line
Neck Plate: Jackson
Neck Binding: White
Pickup Configuration: HH
Bridge Pickup: Jackson High Output Humbucking
Neck Pickup: Jackson High Output Humbucking
Pickup Switching: 3-Position Toggle: Position 1. Bridge Pickup, Position 2. Bridge and Neck Pickups, Position 3. Neck Pickup
Controls: Master Volume, Master Tone
Hardware: Black
Bridge: Jackson Compensated and Adjustable Strings-Through-Body
Tuning Machines: Jackson Sealed Die-Cast
String Nut: Plastic
Strings: NPS, .009-.042 Gauges
Unique Features: White Binding on Neck and Headstock, Black Hardware and "Zebra" Style Pickup Covers
Control Knobs: Dome Style
JS1X
Body & Bridge
Series: JS
Body: Poplar
Shape: Rhoads
Bridge: 6-Saddle String-Through-Body Hardtail w/Block Saddles
Construction: Bolt-On
Finish: Metallic Blue Burst
Neck & Fingerboard
Neck: 1-Piece Maple w/Graphite Reinforcement & Scarf Joint
Profile: Speed Neck
Scale Length: 22.5'' (572mm)
Fingerboard: Rosewood
Radius: 12'' (305mm)
Frets: 24 Jumbo
Nut: Black Plastic
Nut Width: 1.625'' (41.3mm)
Pickups & Hardware
Bridge Pickup: Jackson High Output Humbucker
Neck Pickup: Jackson High Output Humbucker
Controls: Master Volume, Master Tone, 3-Position Blade
Hardware: Black
Strings: NPS, .009 - .042 Gauges
Lo que yo veo es que la JS1X es una guitarra 2/3 (o sea, más pequeña de lo normal) y creo que para alguien adulto se puede ver algo descompensado. En características, son la misma guitarra e excepción del puente (tune-o-matic vs hardtail). Pues yo lo tengo claro, ve por la JS32T. Aunque si puedes subir tu presupuesto, ve por la Demmelition o la KV6, están por los 600 euros, pero están mucho mejor en calidad.
Gracias por la respuesta...y que tal la LTD MH-200QM, si se notaria la diferencia a comparacion de la js32t en cuanto a calidad?
me gusta mucho la MH-401 nt pero sumandole los impuestos y envio ya saldria muy costoso
#4 Compañero, ¿Cuánto es tu presupuesto? Con eso te ayudo a buscar una opción que se ajuste al presupuesto y que tenga bastante calidad.
Pues me gustaria gastar por ahi 300 dolares pero si me decido por pastillas activas tendria que subir aunque no se si valgan la pena ya que estan por los 600 dolares con activas
#6 Por privado te asesoro mejor.
