Line 6 anuncia el nuevo POD HD500X
En resumen:
✓ Mayor poder de procesamiento DSP
✓ Incorporación de anillos LED
✓ Valor estimado 500€ / $700 dolares (*Varia según la región e impuestos)
Extracto de la web line 6:
“POD® HD500 is the best-selling multi-effects floorboard*—and now POD HD500X gives you even more power to define your sound. It’s the ultimate tone palette, whether you want to re-create classics or go somewhere new. And thanks to HD technology, POD HD500X provides the depth, character and touch nuance to inspire your creativity in the studio or on stage. So if you’ve never experienced the flagship of the POD family, now’s the time to check out POD HD500X.”
FEATURES
• Extensive collection of award-winning HD amps for authentic tone and feel
• 100+ studio and stomp effects—use up to eight simultaneously
• Selectable speaker cabinets and mics
• Unparalleled flexibility to craft your tones:
• Dual signal paths
• Multiple routing options
• Dynamic DSP with more power for amps and effects
• Stereo FX loop can be inserted anywhere in the signal chain
• Professional-grade footswitches with bright LED rings for at-a-glance operation
• Comprehensive I/O includes USB 2.0, MIDI, S/PDIF, balanced XLR outputs, integrated mic preamp and more
• Variable input impedance
• L6 LINK™ connection for integration and control of DT-series amplifiers and StageSource® series loudspeakers
• VDI connection for integration and control of James Tyler® Variax® guitars
• 512 user-writable preset locations
• Eight set list banks
• Assignable expression pedal controls amp and effect parameters
• Integrated 48-second looper with dedicated footswitch
• Built-in chromatic tuner Tap tempo
• Professional-grade construction with bent metal chassis, chrome roll bar and die-cast expression pedal
• Downloadable POD® HD500X software editor/patch librarían
Imágenes:
Panel trasero:
![a1db47c9b223758969bef806c1a11-1636691.jpg](https://statics2.soniccdn.com/images/lazy-placeholder.jpg)
Panel frontal:
![e34c56facffd0827a9251b08c7f86-1636691.jpg](https://statics2.soniccdn.com/images/lazy-placeholder.jpg)
+info y Video:
http://line6.com/podhd500x/
En resumen:
FEATURES
• Dual signal paths
Imágenes:
Panel trasero:
![a1db47c9b223758969bef806c1a11-1636691.jpg](https://files2.soniccdn.com/imagecache/3cd/a1db47c9b223758969bef806c1a11-1636691.jpg)
Panel frontal:
![e34c56facffd0827a9251b08c7f86-1636691.jpg](https://files2.soniccdn.com/imagecache/2b1/e34c56facffd0827a9251b08c7f86-1636691.jpg)
+info y Video:
![:brindis: :brindis:](https://statics2.soniccdn.com/images/smilies/brindis.gif)
