Pero pa mi
desgracia hay que esperar 8 meses para comprartela en el color que quieres La chameleon:shock:
Jackson pc1 phil collen:cool:
caracteristicas:
Body:
Body Species:Mahogany with Quilted Maple Top Body Style:Dinky™Pickguard:NoneNeck:
Neck Type:Bolt-On Quartersawn MapleNeck Finish:Neck Binding:N/ANeck Dimensions:3rd Fret: .825", 12th Fret: .890"Fingerboard:
Fingerboard Species:Flame MapleFingerboard Radius:12” to 16” Compound Radius / 304.8 mm to 406.4 mmScale Length:25.5" / 648mmNumber of Frets:24Fret Size:Jumbo FretsNut Material:Nut Width:1.6875 / 43Inlays:Side Dot Position Inlays OnlyElectronics:
Bridge Pickup:DiMarzio® Super 3™ Humbucking PickupMiddle Pickup:DiMarzio® HS2 Stacked Humbucking PickupNeck Pickup:Jackson® Sustainer/DriverPickup Switching:5-Position Blade:
Position 1. Bridge Pickup
Position 2. Bridge and Middle Pickup
Position 3. Middle Pickup
Position 4. Middle and Neck Pickup
Position 5. Neck PickupControls:Master Volume,
Master Tone,
Intensity Control,
Sustainer/Driver On/Off Switch,
Fundamental/Harmonic/Blend SwitchSpecial Electronics:18-Volt Jackson® Sustainer System, CTS® Pots and Switchcraft® SwitchesCase:
Case Information:Deluxe Jackson® Molded Case by SKB®Hardware:
Hardware:Gold-PlatedBridge:Floyd Rose® Original™ double-locking 2-Point TremoloTuners:Die-Cast Tuners
