Estoy a punto de comprarme este ampli de 25w. Me pueden dar opiniones los que los pudieron probar o lo que escucharon? , muchas gracias
Img:
Imagen no disponible
Rage® 258
Item#: 00583600
The basic building blocks of the TransTube® sound are the exclusive designs of the preamp and power amp. The preamp section tailors gain to meet the need for any amount of drive, from crystal clear to thick, smooth sustain. The power amp reacts just like a tube output section by responding to the preamp with natural compression that increases as the amp gets louder. With TransTube®, you get a killer amp with widely ranging dynamics and natural "grit," just like a tube amp!
Features
25 watts (rms)
8 inch super-duty Blue Marvel® speaker
Two switchable channels: clean and lead
3-band EQ
Tape/CD input
Modern/vintage voicing switch
Headphone jack
Weight Packed: 21.00 lb(9.525 kg)
Width Packed: 10"(25.4 cm)
Depth Packed: 17.87"(45.3898 cm)
Height Packed: 15.62"(39.6748 cm)
Especificaciones
# 25 vatios RMS
# altavoz de 8'' (203mm)
# 2 canales conmutables 'clean' y lead
# ecualizador general de 3 bandas
# interruptor de voz de 3-posiciones
# entrada de cinta/CD para practicar
# salida auriculares
# Dimensiones (AxLxF): 16'' (406mm) x 13'' (330mm) x 8'' (203mm)
# Peso: 11 lbs (5kg)
Img:
Rage® 258
Item#: 00583600
Features
25 watts (rms)
3-band EQ
Tape/CD input
Headphone jack
Especificaciones
# 25 vatios RMS
