Y si alguien tuviese alguna información mas acerca de esta guitarra le estaría agradecido.
https://www.thomann.de/es/gibson_lp_custom_57_black_beauty_eb.htm
nakio escribió:Segun tengo entendido, si es esa misma, la del 57 es solida porque imitan al modelo de ese año. y las actuales se supone que tienen los agujeritos. Creo que ninguna custom vienen con camaras, solo con los 9 agujeros.
Alguien escribió:Features:
- Top-of-the-line Gibson Les Paul
- Dual humbuckers with 490R at the neck and a 498T at the bridge.
- Precisely chambered body for diminished weight and enhanced tone
- Stunning multi-ply binding on the body and single-ply binding on the neck
- Mahogany neck with '59 rounded Les Paul profile
- Tune-o-matic with stop-bar tailpiece
- Included hardshell case and certificate of authenticity
Alguien escribió:Wearing a high-gloss ebony black “black beauty” finish, gold-plated hardware, multi-ply body and headstock binding, and the decorative mother-of-pearl “split-diamond” headstock inlay and block position markers in its ebony fingerboard, the Peter Frampton Les Paul is the spitting image of the original. At Frampton’s request, however, it benefits from a slim-carved neck profile for optimum speed, and a weight-relieved mahogany body and carved solid maple top that both lighten the load and enhance the tone.
