Vale la pena una LTD?
zero_cool
#1 por zero_cool el 24/04/2014
Tengo ganas de comprar una LTD KH-202, he visto video y suena bastante bien a mi parecer, es bien rockera... pero quisiera preguntar si alguno de ustedes a tocado esta guitarra y que impresion tienen de ella.
Gracias
    569 €
silenthill_die
#2 por silenthill_die el 24/04/2014
Features: This guitar is a Kirk Hammett signature model, made in Korea. The fretboard is made of rosewood and it has 24 frets. The body is made of basswood. It has a liscensed floyd rose bridge with a whammy bar (2 way). It has 2 EMG passive humbucker pickups (EMG-HZ). It's got 2 volume controls (1 for each pickup) and one tone control which is common for both pickups. So in total it has 3 knobs and a 3-way selector (neck pickup, bridge pickup and both pickups used together). It has ESP locking tuners. My guitar came with an allen key to fix the floyd rose as well as the lockin tuners. It also comes with awesome skull inlays. // 10
Sound: This guitar is perfect for the music I play like rock and heavy metal (lots of Metallica stuff). I generally play it with a micro cube amp or a Fender Frontman amp and a Korg AX10G. I prefer playing it through the Micro Cube even though its a lot smaller. I like the neck pickup for clean tones because it gives a nice warm tone rather than the harsh tone given by the bridge pickup. When I use dirty tones, the bridge pickup is my favorite because it sounds alot heavier. Through the Micro Cube, the guitar is very quiet when I'm not playing it even though the amp is on. I don't get any hissing sounds but then again, I never play very loud. // 8
Action, Fit & Finish: My guitar was set up very well. I have had no problems with my floyd rose so far. Everything is perfect except that sometimes I get a hiss sound when I turn the volume knob for the neck pickup. // 10
Reliability & Durability: I feel that this guitar will stand playing live but I would always keep a backup because ifa string breaks, it would take a long time to fix the string due to the floyd rose. Personally, I would never play live without a backup when I'm using a floyd rose. The finish has ot spoilt yet and it seems that it will last if you take good care of it. // 8
Overall Impression: Again it is perfect if you are a metallica fan or if you like hard rock. I've been using this guitar for one year and so far so good. Even though it is an awesome guitar, if I lost it, I would not buy it again because I like to experiment with different guitars. I would probably buy the KH602 which is a more expensive version of this guitar. I love the whammy bar and the awesome skull inlays but I hate having to change the strings because it take time and is annoying. It is not as simple as a Strat or a Les Paul. I first chose this guitar because of the skull inlays. They are so much cooler than dots. I think it would sound much better with active pickups like the ones kirk uses himself. // 8
Tariu
#3 por Tariu el 24/04/2014
#2 Yo creo que el compañero pide una opinión, no la primera opinión que sale en ultimate-guitar, sin citar la fuente, en otro idioma y que encima está totálmente desactualizada, porque no cumple ya nada de lo que ahí pone, salvo que encuentres una usada de esa época...
La KH202 no está mal, no es mala guitarra pero es flojilla... y pagas bastante firma, como nivel de guitarra en sí se puede asemejar a la LTD M100, un poco superior... desde luego para mi gusto no es una guitarra de 500 euros, la verdad... aunque ahora mismo ya la kh202 no está en catálogo, si no la kh330 (pero es exactamente igual y vale más o menos lo que valía la otra). Es china, lleva pastillas genéricas, ahora lleva puente floyd rose special, que es igual de malo que el que llevaba antes genérico... Es bonita, no está mal terminada y el aspecto vaya, es brutal, pero yo pienso que por ese dinero hay opciones mucho más serias, sinceramente, empezando por la misma marca sin irte a las signature.
A no ser que seas un fanático de kirk hammet o de esos inlays... la guitarra no aporta nada que no aporte otra de su segmento a menor precio y no deja de ser una guitarra negra, por lo que el abanico es bastante amplio para pillar cualquier otra... yo revisaría un poco el catálogo, si no te gusta nada... pues adelante con ella, que igualmente es buena. Si te la venden usada, pues ya es otra cosa, habría que valorar precio, estado... y si el origen es diferente, porque las anteriores koreanas si eran harina de otro costal
JoelMetal_erocaster V
#4 por JoelMetal_erocaster V el 24/04/2014
Mira, no es un mal instrumento, tiene un buen sonido, y si lo mezclas un un Mesa Boogie o un Marshall de 15w para adelante se hace algo decente, si lo que realmente quieres es conseguir el sonido de KIrk Hammett te la recomiendo, pero si buscas tu propio sonido, te puedes buscar una LTD EC1000, que es una guitarra excelente (es lo que dicen por aquí) o te puedes buscar una Epiphone o una Washburn, o para irte por algo mejorcito, una Ibanez Grga32, que te sale por los 200 euros. Pero todo es cuestión de la pruebes y también otras guitarras y encontrar el sonido que te gusta.
pyngwie Baneado
#5 por pyngwie el 24/04/2014
#4 has estado sembrado con tu comentario compañero.
no me parece que asi vayas a ayudar mucho a este muchacho, pues no parece que sepas demasiado de lo que estas hablando.
silenthill tariu tiene razon en lo que te ha comentado. por mi parte te recomiendo algo parecido y es que mires modelos que no sean signatures, que son tan buenos o mejores que los que vienen con firma y ademas con un precio menor.
no he probado ese modelo en concreto, aunque si he probado otros modelos como la mh 330 con floyd rose o una h 351 nt. las dos me parecieron muy apañadas para su precio, sobre todo la 351, que es neckthru y cuerdas a traves del cuerpo, me gusto mucho, buenos materiales y un buen sonido por algo menos de 700€.
la mh 330 es mas sencillita, pero bueno, no estaba nada mal, eso si, tendras que ajustarle el floyd a conciencia porque es bastante malo el jodio y si lo usas a menudo se te va a ir la afinacion mas de lo que te gustaria.
#6 por JoelMetal_erocaster V el 24/04/2014
#5 ¿Como que no se de lo que estoy hablando? no tengo animo de discutir, pero, yo llegue a probar esa guitarra y en verdad es algo decente si quiere el sonido de Kirk, luego le dije si quiere algo similar le di unas ideas, si sabes buscar te encontraras con cosas por el estilo. Dame fundamentos para decir lo que dijiste.
Tariu
#7 por Tariu el 24/04/2014
Un mesa boogie (2000 euros) o un marshall de 15W (100 euros), una LTD EC1000 (1000 euros) o una GRGA32 (200 euros)... en serio estás llevando la comparación por ahí o has abierto el catálogo de instrumentos aleatoriamente??
Mejor no hacer mucho caso a #4 , además que por ejemplo esa LTD ya de base es bastante mejor guitarra que una epi o esa ibanez que nombra... que la LTD no, pero tampoco es el "sonido" de hammett, además que el sonido de hammett viene, como todos los músicos, de las manos y del ampli más que de la guitarra... por lo demás, lo dicho.
pyngwie Baneado
#8 por pyngwie el 24/04/2014
#6 para que amiguete, que quieres que te diga. no tengo nada que decir, ya lo has dicho tu todo.
souldrainer
#9 por souldrainer el 24/04/2014
:sorprendido: Cuanta gente hay que habla de oidas.Yo tengo una ltd kh-602 (Koreana)y no sueno como Kirk :risa: Si te puedo decir que he probado LTD de esa gama y tienen una relacion calidad/precio muy buena.
pyngwie Baneado
#10 por pyngwie el 24/04/2014
yo creo que esta es la unica guitarra con la que sonaras como su "endorser"
pyngwie Baneado
#11 por pyngwie el 24/04/2014
zero cool perdona por el :offtopic: :D
#12 por JoelMetal_erocaster V el 24/04/2014
#7 Solo son sugerencias, aquí donde vivo una LTD EC1000 no sale 1000 euros, sale máximo 700, y solo es una sugerencia, yo toque la KH 202 con un Mesa Boogie de 15W y me costo (con cable, congalte y todo eso) 600 euros, por eso prefiero la Grga32 porque así te ahorras unos 200 y suena del cañón. #9 yo dije que es decente si quieres sonar a Kirk, pero yo toque con un Mesa Boogie (la marca de amplis de Metallica) de 15W, y todo comprado de tiendas de música, así que no me vengan con que estoy equivocado, o sino, aclárenme que es lo que digo mal.
