Hola se que estareis hartos de post de este tipo pero queria pediros opinion entre dos guitarras. no m eimporta que no hayais probado la guitarra pero si habeis probado el puente las pastillas etc que llevan pues tambien. bueno las guitarras en cuestion son estas:
Pro Series King V™ KVMG jackson (610 euros)
![8a354f9607a212ddb813510de132c-2090512.png](https://statics2.soniccdn.com/images/lazy-placeholder.jpg)
Body Shape: King V™
Body Material: Alder
Body Finish: Gloss
Neck Material: 1-Piece Maple Neck-Through-Body with Graphite Reinforcement and Scarf Joint
Neck Shape: Speed Neck
Neck Binding: 1-Ply White
Scale Length: 25.5" (648 mm)
Fingerboard Radius: 12" to 16" Compound Radius (304.8 mm to 406.4 mm)
Number of Frets: 24
Fret Size: Jumbo
String Nut: Floyd Rose® R3 Locking
Nut Width: 1.6875" (42.8 mm)
Truss Rod Nut: 4 mm Hex
Neck Plate: None
Neck Finish: Oiled
Fingerboard: Ebony
Position Inlays: Alumiloid Shark Fin
Bridge Pickup: Direct Mount EMG® 81
Neck Pickup: Direct Mount EMG® 89
Controls: Master Volume, Master Tone
Pickup Switching: 3-Position Toggle: Up: Neck Pickup, Middle: Bridge and Neck Pickups, Down: Bridge Pickup
Pickup Configuration: HH
Bridge: Floyd Rose® FRT-O2000 Double-Locking Tremolo (Recessed)
Tuning Machines: Jackson® Sealed Die-Cast
Orientation: Right-Hand
Pickguard: None
Control Knobs: Knurled Flat-Top Black
ltd arrow 401 (670 euros)
![13b1e81176e4a7ce732bc3428aff4-2090512.png](https://statics2.soniccdn.com/images/lazy-placeholder.jpg)
Construction: Set-Thru
Scale: 25.5"
Body: Mahogany
Neck: 3Pc Maple
Fingerboard: Rosewood
Fingerboard Radius: 350mm
Finish: Black
Nut Width: 42mm
Nut Type: Locking
Neck Contour: Thin U
Frets/Type: 24 XJ
Tuners: Grover
Bridge: Floyd Rose Special
Neck PU: EMG 85
Bridge PU: EMG 81
Electronics: Active
Electronics Layout: Vol/Toggle Switch
Estoy abierto a sugerencias de guitarras pero eso si quiero que sean flyngs
Gracias por la ayuda.
![8a354f9607a212ddb813510de132c-2090512.png](https://files2.soniccdn.com/imagecache/05a/8a354f9607a212ddb813510de132c-2090512.png)
Body Shape: King V™
Body Finish: Gloss
Number of Frets: 24
Fret Size: Jumbo
Neck Plate: None
Neck Finish: Oiled
Fingerboard: Ebony
Pickguard: None
![13b1e81176e4a7ce732bc3428aff4-2090512.png](https://files2.soniccdn.com/imagecache/c0f/13b1e81176e4a7ce732bc3428aff4-2090512.png)
Scale: 25.5"
Body: Mahogany
Neck: 3Pc Maple
Finish: Black
Nut Width: 42mm
Nut Type: Locking
Frets/Type: 24 XJ
Tuners: Grover
Neck PU: EMG 85
Bridge PU: EMG 81
Electronics: Active
