ENAMORADO DE UN SOLO DE GUITARRA ¿ALGUIEN ME LO TRANSCRIBE?
Richi_CA Baneado
#1 por Richi_CA el 28/12/2011
Hola estoy enamorado del solo que hace Adam en el video que viene a continuacion,si alguien fuera tan amable de hacerme una tab o decirme como puedo imitar el solo....SE LO AGRADECERIA ENORMEMENTE.
Es a partir del minuto 5:27 hasta que termina el solo (cuando empieza a sonar la bateria)
Muchas gracias aqui dejo el video http://www.youtube.com/watch?v=JeIByohOgp0
  • Millenium Rookie E-Drum Set
    189 €
  • -75%
    Eventide Blackhole (descarga)
angel-m-c
#2 por angel-m-c el 19/01/2012
A ver si es esto lo que buscas
E|------------------------------------------------
B|-----------–------------------------------------
G|----4-----4-----4-----4-----6—--–-6-----6-----6-
D|-4-----4-----4-----4-----6-----6-----6-----6----
A|------------------------------------------------
----6-----6-----6-----6-----6-----6-----6-----6|
-4-----4-----4-----4-----4-----4-----4-----4---|
Where you are seems to be
As far as an eternity
Outstretched arms open hearts
And if it never ends then when do we start?
I'll never leave you behind
Or treat you unkind
I know you understand
And with a tear in my eye
Give me the sweetest goodbye
That I ever did receive
|REFRÃO|
E|-7-7-x7-x7-x7-x-x6-6-x6-x6-x6xxx-6-6-x6-x6-xx6-6-6-2-2-x2-x2-xx-x|
B|-7-7-x7-x7-x7-x-x6-6-x6-x6-x6xxx-7-7-x7-x7-xx6-7-6-4-4-x4-x4-xx-x|
G|-8-8-x8-x8-x8-x-x7-7-x7-x7-x7xxx-8-8-x8-x8-xx6h8p6-4-4-x4-x4-xx-x|*(repete)
D|-----–-----—-----------------------------------------------------|
A|–----------------------------------------------------------------|
E|-----------------------------------------------------------------|
Pushing forward and arching back
Bring me closer to heart attack
Say goodbye and just fly away
When you comeback
I have some things to say
How does it feel to know you never have to be alone
When you get home
There must be someplace here that only you and I could go
So I can show you how I
(riff1)
Dream away everyday
Try so hard to disregard
The rhythm of the rain that drops
And coincides with the beating of my heart
Or treat you unkind
(|REFRAO|)
When you comeback
When you get home
So I can show you how I feel
(Solo)
E|-------------------11----11~-------------14-------14-------
B|--------11-9~–--11----11------15~--15h16----15h16-----15h16
G|-8-8-11-----------------------—--–-------------------------
D|-----------------------------------------------------------
A|-----–-----—--------------------------------------------–--
E|-----–-----—--------------------------------------------–--
-14-------14-------------------------------------------------|
----15h16----16-15-------------------------------------------|
-------------------15-13----13-13----------------------------|
-------------------------16-------16-15-16-16-15-13-15-16----|
B|------------------9----------9-11~--------9----------------------
G|-11h13/p11p10/h11—--11-10-11--------10h11---8h10-11-----8--------
D|-----–-----—----------------------------------------8-9--------8-
A|-----–-----—----------------------------------------------9-11---
E|-----–-----—--------------------------------------------–-----—--
-14p13-14p13----11---11-11-14--11---11-11-14--11-------|
-------------11-11---11-11-11--11---11-11-11--11-------|
Lo saque de aqui:
http://www.acordesytabs.com/97350/Maroon-5/Sweetest-goodbye.html
ramonpolispan
#3 por ramonpolispan el 19/01/2012
Las transcripciones es conveniente pasarlas con fuente "courier", que tiene todos los tipos con el mismo ancho, si no se desplaza todo. Como el foro no permite cambiar de fuente de forma intuitiva, es mejor copiar los tabs en Notepad y ponerlo como archivo adjunto.
angel-m-c
#4 por angel-m-c el 19/01/2012
#3 OK para la proxima ya lo se, gracias y perdonar.
ramonpolispan
#5 por ramonpolispan el 19/01/2012
jeje, no hay nada que perdonar. Un saludo y gracias por colaborar con el foro.
