Estoy indeciso entre estos noise gate baratillos.
Tonyguitar
por el 11/02/2019
Hola compañeros, estoy mirando un noise gate baratillo para comprarme, estoy entre estos:
Primero:
https://www.aliexpress.com/item/Rowin-Guitar-Noise-Killer-Noise-Gate-Suppressor-Effect-Pedal/32957026225.html?spm=2114.search0104.3.133.260d2fe5fcVU7s&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10547_319_10891_317_10548_10696_10084_453_454_10083_10618_10307_10820_10821_10301_10303_537_536_10902_10059_10884_10887_321_322_10103-10891,searchweb201603_55,ppcSwitch_0&algo_expid=c18ea43c-339d-4704-b675-bf018546f7e6-20&algo_pvid=c18ea43c-339d-4704-b675-bf018546f7e6&transAbTest=ae803_3
Segundo:
https://www.aliexpress.com/item/NOISE-GATE-Guitar-Effect-Pedal-Noise-Reduction-Guitar-Pedal-Zinc-Alloy-Shell-True-Bypass-Guitar-Parts/32967246004.html?spm=2114.search0104.3.245.260d2fe5fcVU7s&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10547_319_10891_317_10548_10696_10084_453_454_10083_10618_10307_10820_10821_10301_10303_537_536_10902_10059_10884_10887_321_322_10103-10891,searchweb201603_55,ppcSwitch_0&algo_expid=c18ea43c-339d-4704-b675-bf018546f7e6-36&algo_pvid=c18ea43c-339d-4704-b675-bf018546f7e6&transAbTest=ae803_3
Tercero:
https://www.aliexpress.com/item/ammoon-AP-06-Noise-Gate-Electric-Guitar-Effect-Pedal-Noise-Suppressor-True-Bypass/32828349970.html?spm=2114.search0104.3.16.5b936177njwFK1&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10547_319_10891_317_10548_10696_10084_453_454_10083_10618_10307_10820_10821_10301_10303_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_55,ppcSwitch_0&algo_expid=caf4b436-f8cd-4fc3-ad81-5b24d1194ef3-2&algo_pvid=caf4b436-f8cd-4fc3-ad81-5b24d1194ef3&transAbTest=ae803_3
Cuarto:
https://www.aliexpress.com/item/Caline-CP-39-The-Noise-Gate-Guitar-Noise-Reduction-Effect-Pedal-Aluminum-Alloy-With-True-Bypass/32864571450.html?spm=2114.search0104.3.30.5b936177njwFK1&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10547_319_10891_317_10548_10696_10084_453_454_10083_10618_10307_10820_10821_10301_10303_537_536_10902_10059_10884_10887_321_322_10103-10891,searchweb201603_55,ppcSwitch_0&algo_expid=caf4b436-f8cd-4fc3-ad81-5b24d1194ef3-4&algo_pvid=caf4b436-f8cd-4fc3-ad81-5b24d1194ef3&transAbTest=ae803_3
Como veis hay un monton, no me voy a gastar 100 euros en un MXR por que ya tengo un monton de pedales sueltos de marcas baratas y estoy contentisimo con ellos, chorus nux, delay andoer, ecualizador artec etc, todos truebypass y contentisimo con ellos.
La cuestion es que compre este y vino defectuoso:
https://www.aliexpress.com/item/MOSKY-MP-40-Noise-Gate-Guitar-Pedal-Noise-Reduction-Suppressor-Electric-Mini-Single-Guitar-Effect-Pedal/32965046917.html?spm=2114.search0104.3.319.260d2fe5PnfLVj&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_10547_319_10891_317_10548_10696_10084_453_454_10083_10618_10307_10820_10821_10301_10303_537_536_10902_10059_10884_10887_321_322_10103-10891,searchweb201603_55,ppcSwitch_0&algo_expid=c18ea43c-339d-4704-b675-bf018546f7e6-47&algo_pvid=c18ea43c-339d-4704-b675-bf018546f7e6&transAbTest=ae803_3
el moska este ya no me fio, asi que lo que me gustaria es que si habeis probado alguno de los que he puesto y os ha dado buen resultado ya me comentais y asi me decido por uno de ellos, gracias de antemano.
    Kemper Profiler Player
    579 €
  • -27%
    432 €
  • -16%
    Daddario NYXL0946
    11,7 €
Zhu Zaiyu (VicAr)
por el 11/02/2019
No conozco ninguno de ellos.
No me gustan los que no tienen loop.
El uso de un amplificador "higain" con la ganancia casi a tope, y con la de la guitarra al máximo, me obligaba a utilizar un pedal de este tipo.
Compré para probar el Behringuer y, aunque funcionaba, no me gustaba el corte como lo hacía.
Estuve leyendo un hilo, bastante interesante, de como utilizar el Boss, y ahí me decidí a comprar uno nuevo y mejor.
Me costó decidirme. En la búsqueda vi un vídeo de un compañero del foro. que los fabrica él (con su propia marca), y me decidí.
El compañero me dio todas las explicaciones que, sobre mis dudas, le pedí. Y muchas más. Incluso se ofreció a enviarme fotos del interior.
No lo conozco pero me parece una excelente persona. Cuando se lo encargué, no quería darme el número de cuenta hasta que yo tuviera el código de correos.
El precio no es tan bajo como los que has mencionado.
Con los conocimientos que tienes de electrónica, yo creo que deberías ponerte en contacto con él y contrastar opiniones.
Ahora sé lo que es disfrutar de la alta ganancia sin ruidos molestos.
Suerte y un abrazo
Tonyguitar
por el 11/02/2019
VicAr escribió:
En la búsqueda vi un vídeo de un compañero del foro. que los fabrica él, y me decidí.
Yo tengo chorus nux y delay adoner y otros pedales de estos baratillos que verdaderamente me gustan mas que otros boss y mxr que he tenido como chorus, y otros efectos, por eso pense en uno de estos baratos.
Lo de hacerlo yo mismo es una opcion, ¿que montaje es el que el compañero ese del foro que tu dices te hizo y asi lo miro?
Zhu Zaiyu (VicAr)
por el 11/02/2019
Perdón. El compañero es Drjack.
Su anuncio: https://www.guitarristas.info/anuncios/clon-decimator-gstring-con-mejoras/724597
Creo que en su perfil está el vídeo del que te hablo.
Tonyguitar
por el 11/02/2019
tiene buena pinta, pero paso de gastarme tanto en un noise gate, ni tampoco tengo ganas de hacerme uno, a ver si alguien ha probado alguno de los que he puesto en los enlaces, gracias!! ;)
hijodekain
por el 11/02/2019
El primero parece un clon del Mooer. Un compañero mío tiene el Mooer y le funciona bien, el está encantado por qué tenía bastantes problemas de acoples y ruidos con un blackstar. Yo no lo he probado pero por lo que le escucho cuando tocamos me parece que va muy bien, nada raro, ni cortes bruscos.
Txema
por el 11/02/2019
Hola Tony,
Tengo el Rowin y lo recomendaría por ese precio. No tengo ninguna queja. Tanto por la entrada del ampli como por el loop funciona muy bien. Los otros no los he probado.
Tonyguitar
por el 11/02/2019
Txema escribió:
#7 por Txema hace 1 hora
Hola Tony,
¿y el Rowin este cuando lo tienes activado te consume tono o te colorea o es como cuando lo tienes apagado?
¿le hiciste estas pruebas para ver que tal responde a esto? yo tenia el de harley benton y ese chupaba un poco de tono, poco pero se notaba, tanto encendido como apagado.
hijodekain escribió:
#6 por hijodekain hace 2 horas
gracias tio.
Txema
por el 11/02/2019
Hola Tony,
No colorea ni cambios de tono. No tiene un corte brusco. Por el precio no se puede pedir más y ya ha sustituido a mi vieja Alesis micro gate.
Txema
Fernan
por el 12/02/2019
hola Tron, ya sabes que yo de estas cosas npi, básicamente lo que hace es reducir ruido? o por las malas traducciones que he leído, a que ruido se refieren estos pedales, curiosidad simplemente
Tonyguitar
por el 12/02/2019
Gracias txema pillare ese, guay así ya tengo mi pedalboard al completo.
Fernan, es una puerta de ruido.
Cuando no tocas, corta la señal.
Zhu Zaiyu (VicAr)
por el 12/02/2019
#11
Tengo curiosidad por saber como lo implementas en tu cadena.
Tal y como lo explican en el primer mensaje de https://www.guitarristas.info/foros/conexion-x-puerta-ruido-boss-ns2-x-connection/155806
Si tocas con ganancia generada antes del amplificador (y en un canal limpio del ampli), el pedal "puerta de ruido" será conveniente ponerlo al final de los pedales de ganancia y antes de la entrada del amplificador.
Si se utiliza un canal de mucha ganancia del amplificador, me parece que, habría que ponerlo en el loop de efectos para evitar el ruido del propio amplificador. Pero en este caso el ampli ya ha podido amplificar el ruido de entrada, ya sea de la guitarra, ya sea de pedales.
Es por eso por lo que decidí comprar un pedal de los que se pueden conectar en "X", ya que puede actuar en ambos casos. Y yo uso bastante ganancia del ampli.
Puede que otra solución sea un pedal puerta de ruido por el in, y otro por el loop.
Por eso mi curiosidad ¿tú como lo resuelves?
Gracias, un saludo.
