Hotone Ampero II Stomp - Nuevo firmware con escenas
disperso
por el 01/05/2024
Abro nuevo hilo, porque no hay uno específico del modelo II Stomp.
Ampero II Stomp
Firmware Release Note
Version 2.0.0
Released 4/24/2024
This V2.0.0 firmware update brings you brand new UI and more powerful features (e.g. Scene function). Please read the notice carefully below before updating.
Notice
 After this update, all global parameters (including global settings, system language, effects chain templates, etc.) on your Ampero II Stomp will be restored to default. Please manually backup your global settings before updating.
 This update will change the unit’s patch data structure, which means, during the first power-up progress after updating, there will be a few more seconds needed for Ampero II Stomp to convert patch data. In this case, to prevent any possible issue, please backup your patches first before updating.
 Use V2.0.0 firmware with Ampero II Editor V1.0.3 ONLY. To update your unit, we recommend to use Ampero II Stomp software V1.3.0.
New Features
1. Brand new UI
2. Scene function added
3. CTRL function updated to Effect Slot On/Off function
4. Expression pedal state switching function added
5. Drum machine function added
6. Patch footswitch function settings added (Global > Controls)
https://youtu.be/DjHFNT8jktE
    102 €
  • -23%
    Harley Benton JAMster Guitar
    30 €
Victor Gabriel
por el 02/05/2024
Ufff.. yo lo acabo de instalar "por tu culpa" y lo he pasado mal. Se he ha cortado el update a la itad y no iba ni pa alante ni pa aptras.
A la 6ª vez parece que se ha instalado correctamente, pero no conextaba con el software de PC, mirando por ahi en un video he visto que hay que usar el Ampero Stage en lugar del Ampero Stomp a partir de ahora. Casi crei tenia un pisapapeles nuevo.
La interzaf de la pantalla es espantosa, sera cosa de acostumbrarse.
Por lo demás, parece que hay unos cuantos amplis nuevos, el tema de las escena, tendre que probarlo a ver si realmente me aporta algo, son 3 escenas por cada patch.
La interfaz en genera, me gusta menos tanto la del la pedalera coo la del PC, pero sera cosa de acostumbrarse.
Me ha repsetado las IR que tenia cargadas al hacer el update, cosa que con el anterior update no me funciono y las tuve que volver a cargar.
En cuanto mi mujer salga por la puerta me pongo a probar los amplis nuevos.
disperso
por el 02/05/2024
Je je je, la verdad no lo he probado, tengo el aparato en un cajón prácticamente desde que lo compré. Puse la información, porque el tema de las escenas es algo que se esperaba de hace bastante tiempo y no llegaba. Cuando me vea con un poco de ánimo para ello, lo pruebo.
Aquí un vídeo en español en el que comentan la forma de actualizar:
https://youtu.be/e8npmkDSDMI
Joan Ribas
por el 06/05/2024
Otro usuario de la ampero II aquí.
Pues el otro dia me instalé la nueva versión, y bastante contento; aparte de escenas, drum machine, etc, noto que el sonido también lo han tocado: el ruido digital de freidora en altas frecuencias lo han reducido mucho, al punto que antes tenia la Eq global activada para limpiar, y con la nueva versión los presets me suenan igual que antes, pero ahora sin la EQ global activada. El volumen también lo han subido, antes tenia el volumen de amplis, cabs y eq bastante subidos, y ahora los he tenido que bajar todos para no reventarme los tímpanos.
Eso si, la han cagado con la interfaz, antes estaba mucho mejor, para mi gusto, pero bueno, eso es un detalle menor. A falta de investigar más, yo la veo una muy buena actualización.
Casi que podríamos convertir este hilo en el oficial de "comunidad de..." no?
disperso
por el 06/05/2024
¿Hay forma de cambiar el título o tiene que hacerlo un moderador?
Joan Ribas
por el 06/05/2024
Ni idea compañero, no lo he hecho nunca.
Tonyguitar
por el 04/08/2024
Buenas, andaba buscando un hilo sobre este aparato por que yo tuve la helix lt y la vendí por ser muy grande y aparatosa, y me volví a los efectos boss.
La cosa es que este lo veo muy pequeño y además
Parece sonar más o menos estilo helix.
Me pille una valeton gp100 y me da lo que yo necesito menos 2 cosas:
1, no puedo cargar dos líneas dual amp y poner un fender barman con un delay por la salida stereo canal derecho y, poner otra línea con un jcm800 por ejemplo con una reverb y sacarla por el canal izquierdo.
Así podía tocar en stereo y la sensación era impresionante.
Otra cosa es, que enchufado a un altavoz de guitarra real tipo celestion v30 o G12T-75, a veces añadía una simulación de altavoz pero con un truquillo que dejaba pasar un 30% de señal con emulación de altavoz y un 70% sin emulación, y eso coloreaba el.sonido de forma muy agradable pq añadía un toque extra de carácter al altavoz que estaba usando y cambiaba el tono de este sin que fuese algo exagerado, solo un pelin.
Pues estas cosas no se pueden hacer con el valeton.
Se puede hacer con este aparato?
Lo digo pq si no se puede me olvido y me miro el hx stomp, muchas gracias.
Sam
por el 08/10/2024
Hola,
Disculpad que me meta en este hilo, pero no encuentro uno específico para la ampero stage. Os quisiera hacer un par de preguntas. Busco algún multiefectos que me permita controlar los presets (cadena de efectos) via midi sin simulaciones para añadirlo al resto de mis pedales y que todo sea controlado des de una boss es-8 (switcher). Se puede?
Estoy dudando mucho entre la ampero stage y la boss gt1000core. Lo cierto es que no me interesan demasiado ni los amplis ni los ir (aunque estará bien tenerlos por si se muere el ampli a mitad de bolo o...). No sé qué tal es la calidad de los efectos como para enviarlo al ampli (overdrives, tremolo, reverbs, delays, eq 10 bandas, cvompresor).
Y por último, el tema de que pueda meter la voz también és interesante, pero no sé qué tal suena y qué tal son los efectos (busco básicamente: doubler y reverb).
Ahora éstá a 560 en amazon, pero no sé si pido demasiado. La gt1000core no me va a servir para voz, pero no sé si los efectos estarán más logrados. Sonarán ambas raro por el ampli?
Bueno, Muchas gracias y disculpad mi intromisión!
Un saludo!
Joan Ribas
por el 15/10/2024
Tonyguitar escribió:
#7
Muy buenas, como veis no hay mucha parroquia usando el stomp (creo que es el punto flaco del cacharrito). Aunque sea tarde, despejo las dudas, por si alguien más las tiene. Soy muy novato en esto, así que tampoco puedo despejar muchas.
Si, en el ampero stomp puedes cargar dos lineas en paralelo, sin problema.
Aqui ni idea, lo siento. Activar/Desactivar cabs/IR por supuesto, pero lo del truquillo no te puedo decir
Controlar presets o efectos via midi si, de hecho me acabo de pillar la chocolate para eso mismo y sin problemas, pero desconozco la Boss que mencionas. Respecto a la calidad de efectos, no te puedo decir, no tengo mucho donde comparar..
Si no los conoceis, pegadle un ojo a los grupos que hay en facebook, seguramente os resuelvan todas las dudas en un periquete...
Saludos!
disperso
por el 15/10/2024
Video en el que comentan el tema de las escenas:
https://www.youtube.com/watch?v=ltj7QhZ916Y
Tonyguitar
por el 15/10/2024
disperso
Muy bueno tio, gracias.
Tonyguitar
por el 15/10/2024
por Joan Ribas hace 3 horas
#7
gracias brother!! ;)
Equipo relacionado
