Limpieza de los mastiles EVH
Las Wolfgang no van barnizadas, yo tengo una.
Van en cera y aceite para armas, se limpia como las Music man, compra en la ferretería lija de alambre de esa suave como de hilo de acero, lana de acero creo que se llama, pero de la más suave, encinta las pastillas para que no se peguen las virutas del hierro.
lijas y luego das aceite de armas y cera (el aceite de armas en una armeria y la cera en ferreterias) y pules con la lana de acero y luego frotas con un paño que no deje hilos hasta que brille.
Esto es lo que pone en la página de Music Man, te enlazo el vídeo que hay un vídeo en Youtube.
How do I maintain the "unfinished" neck on my Ernie Ball Music Man guitar?
Some of our instruments have necks that are finished with a glossy or matte polyester finish. These necks can be cleaned and maintained with a polish cloth similar to the body of the instrument.
However, many of our necks are not finished that way. They are finished with tru-oil and gunstock wax for a smooth natural feel.
For routine conditioning and cleaning of these necks we recommend Ernie Ball Wonder Wipes Fretboard Conditioner.
If the Wonder Wipes are not available try using a high grade of lemon oil. It will work both on maple, rosewood and ebony. If the neck is very dirty, you can use a small amount of Murphy's Oil Soap, diluted 3:1 with water, to clean it. Keep in mind that if the dirt has gotten into the wood, it cannot be removed except by sanding it down, which we do not recommend a lot of. It is better to keep it clean in the first place. Washing your hands first helps!
On an maple neck, some discoloration after many hours of playing is normal.
An annual (or so) dose of tru oil and gunstockwax will help to keep the neck maintained; we use and recommend Birchwood-Casey Tru-oil, but any good quality gunstock oil will work.
Birchwood-Casey products are available at most sporting goods or gun stores, or now you can order them direct. Their web address is http://www.birchwoodcasey.com.
Be sure to follow all of the manufacturers recommended safety precautions when using any oils or waxes.
https://www.youtube.com/watch?v=24yWr2LRmJY&feature=youtu.be
De nada y un consejo, los mástiles se limpian ANTES de que se pongan perdidos de roña, luego hay que andar puliendo y lijando.
Con un mantenimiento periodico no debería llegar a eso.
Por cierto deberiais tener el manual de la guitarra, allí explican un poco esto; aparte de poner que Eddie nunca limpia sus guitarras, pero ese es otro tema.
Os enlazo el manual.
http://support.evhgear.com/manuals/EVH_Wolfgang_OwnersManual.pdf
