Tenía esta duda y no sé si valdrá por el tema de resistencias (ohmios).
¿Me sirve esta etapa o deberia pillarme otra?
THE T.AMP E800
the t.amp E-800 stereo amplifier - output power: 2x 440W into 4 Ohms, 2x 240W into 8 ohms (@1kHz, THD<=0.1%). Bridged mode: 1x 800W into 8 Ohms (please check cable configuration for bridged on rear of unit). Frequency response: 10Hz-20kHz; damping factor: >120; inputs: XLR and TRS jack (balanced); outputs: Speakon; DC, short circuit, temperature and limiter protection. Power Supply: 230V~50Hz. 19"/2U rack. Dimensions (WxDxH): 482 x 341.5 x 88mm, 19", 2U
La pantalla en cuestión es:
HARLEY BENTON G212 VINTAGE
Harley Benton G212 Vintage guitar cabinet - 2x 12" Celestion Vintage 30 speakers, 120watts/8ohm, 2x 60watts/16ohm, mono/stereo (switchable). Manufactured from 16mm plywood, black Tolex trim strip. Dimensions: 520 x 742 x 300mm. Weight: 25kg.
Muchas gracias
