Nuevo Line 6 POD HD500X
haderms
por el 10/07/2013
Hola amigos acá les dejo la inofrmación del nuevo multiefectos de lIne 6, el POD HD500X
Lista de Amplis:
Bogner® Uberschall
Divided by 13 JRT 9/15
Dr. Z® Route 66
ENGL® Fireball 100
Fender® Bassman® ("Normal" channel)
Fender® Bassman® ("Bright" channel)
Fender® Blackface Deluxe Reverb® ("Normal" channel)
Fender® Blackface Deluxe Reverb® ("Vibrato" channel)
Fender® Twin Reverb® (“Normal” channel with “Bright” switch off)
Fender® Twin Reverb® ("Vibrato" channel with “Bright” switch on)
Gibson® EH-185
Hiwatt® Custom 100 (DR103)
Line 6 Doom
Line 6 Epic
Line 6 Elektrik
Marshall® JCM-800 (2204)
Marshall® JTM-45 MkII ("Bright" channel)
Marshall® JTM-45 MkII ("Normal" channel)
Marshall® “Plexi” 1959 Super Lead ("Normal" channel)
Marshall® “Plexi” 1959 Super Lead ("Bright" channel)
Mesa/Boogie® Dual Rectifier®
Park 75 ("Bright" channel)
Park 75 ("Normal" channel)
Soldano® SLO100(“Clean”)
Soldano® SLO100 (“Crunch”)
Soldano® SLO100 (“Overdrive”)
Supro® S6616
Vox® AC-15
Vox® AC-30 (Top Boost)
Ampeg® B-15NF Portaflex®
100+ STUDIO AND STOMP EFFECTS
Close
Dynamics
Noise Gate
Hard Gate
Tube Comp
Red Comp
Blue Comp
Vetta Comp
Boost Comp
Distortion
Tube Drive
Screamer
Overdrive
Classic Dist
Heavy Dist
Color Drive
Buzz Saw
Facial Fuzz
Jumbo Fuzz
Fuzz Pi
Jet Fuzz
Line 6 Drive
Line 6 Distortion
Sub Octave Fuzz
Octave Fuzz
Pitch/Mod
Bass Octaver
Pitch Glide
Smart Harmony
Pattern Tremolo
Panner
Bias Tremolo
Opto Tremolo
Script Phase
Panned Phaser
Barberpole Phaser
Dual Phaser
U-Vibe
Phaser
Pitch Vibrato
Dimension
Analog Chorus
Tri Chorus
Analog Flanger
Jet Flanger
AC Flanger
80A Flanger
Frequency Shifter
Ring Modulator
Rotary Drum
Rotary Drum+Horn
Filter
Voice Box
V-Tron
Q Filter
Vocoder
Seeker
Obi Wah
Tron Up/Down
Throbber
Slow Filter
Spin Cycle
Comet Trails
Octisynth
Synth O Matic
Attack Synth
Synth String
Growler
EQ
Graphic EQ
Parametric EQ
Studio EQ
4 Band Shift EQ
Mid Focus EQ
Vintage Pre
Delay
Ping Pong
Dynamic Delay
Stereo Delay
Digital Delay
Dig Delay w/ Mod
Reverse
Lo Res Delay
Tube Echo
Tape Echo
Sweep Echo
Echo Platter
Analog W/Mod
Analog Echo
Auto-Volume Echo
Multi-Head
Wah/Vol
Fassel
Weeper
Custom Chrome
Vetta Wah
Throaty
Conductor
Colorful
Volume
Pan
Reverb
Plate
Room
Chamber
Hall
Echo
Tile
Cave
Ducking
Octo
Spring
‘63 Spring
Particle Verb
...Y mas!
[imghttp://l6c.scdn.line6.net/data/6/0a06434c14e2951dbbd6b10747/image/png/file_r15542.png][/img]
olmost
por el 10/07/2013
¿Y que hay de nuevo?
haderms
por el 10/07/2013
#2 Pues nada... Mas de lo mismo se podría decir.
granmago90
por el 11/07/2013
Alguna novedad habrá mas hombre. De momento solo se que se iluminan los pulsadores para actuar de noche :D
lpazc
por el 01/08/2013
Y acomparación de la GT100?? O algo similar? Porque esta al mismo precio de la GT100
vidaljuanes
por el 02/08/2013
Es igual a la HD500 sin X.
Dedos Cortos
por el 02/08/2013
lo nuevo que trae es que tiene mejor procesador, como para poner 8 armonizadores inteligentes (estoy exagerando) y no colapse
lpazc
por el 02/08/2013
entonces sería mejor comprar la HD500? (mas que nada por el precio).
maurozao
por el 06/08/2013
Algunas veces me he liponeer efectos y el dsp me a cortado el rollo yo la compre pensando que tambien la usarías como vocal. Al mismo tiempo. Pero a sido una desilucion. Pero he visto un Videoconferencia de comparaciónentre. 500 500x y también. Se peta el dsp. Asy que no me parece gran cmejora
Fatman_1987
por el 14/12/2013
Perdonad por reflotar el hilo pero es por no abrir otro. Estoy en proceso de reemplazar mi Boss GT-6 y la HD500 es mi principal opción. ¿Entonces la única diferencia real entre la 500 y la X es la doble capacidad de proceso? Teniendo en cuenta que lo máximo que uso es distorsión+modelado de ampli y pantalla+delay+reverb+pitch shifter, es decir 5 o 6 efectos como máximo, ¿me merece la pena el gasto extra?
blindstar
por el 26/12/2013
Yo tuve el HD 500 y la verdad que fue una decepción. Usando los modelados, no podia combinar un delay con pitch. Creo que en ese caso es 100% recomendable la GT-100.
maurozao
por el 27/12/2013
Fatman con lo que tu quieres poner se te peta el dsp. Asy que yo me comprarían la hd 500x pero aun asy puede que llegues a petar el dsp porque es un 20%mas no un 50 % la otra opciones es usar un par de efectos yo he pensado en un overdrive y una puerta o como tercera opcion no usar modelado de ampli jaaja
