El ampli en cuestión es este:
http://www.peavey.com/products/index.cfm/item/804/116535/Bandit%26reg%3B%26nbsp%3B112
Tiene unos 4 años, pero apenas se usó por que el chico dejó de tocar.
Sus caracteristicas son estas:
- 100 Watts (rms) into 4 Ohms (w/external speaker)
- 12" Blue Marvel® speaker
- High and Low Gain inputs
- TransTube tube emulation circuitry
- Footswitchable Clean and Lead channels
- 3 band passive EQ on each channel
- 3 position EQ/Gain Voicing switch on each channel
- Reverb with level control
- Footswitchable Boost with level control
- ¼" stereo Speaker Simulated Direct Out jack with level control
- Footswitch optional
- 80 Watts (rms) into 8 Ohms
- Weight Unpacked: 40.00 lb(18.144 kg)
- Weight Packed: 48.00 lb(21.772 kg)
- Width Packed: 15.75"(40.005 cm)
- Height Packed: 28.37"(72.0598 cm)
- Depth Packed: 23.87"(60.6298 cm)
A ver que me podeis decir, gracias.
