tengo un problema en decidirme cual guitarra me comprare ya que las 2 me parecen muy buenas
dean vmnt angel of death:
[ Imagen no disponible ]
TopMahogany
BodyMahogany
NeckMahogany
Scale Length25 1/2"
Neck TypeSet Neck 15" RADIUS
Neck ProfileDave Mustaine Spec D-Shapped
FingerboardEbony
InlaysPearl Dave Mustaine Custom
# of Frets24
KnobsBlack Dome
Hardware ColorBlack
BridgeTune-O-Matic
Pickup (Neck)Seymour Duncan Live Wire
Pickup (Bridge)Seymour Duncan Live Wire
BindingSingle Ply White Neck
FinishGloss
ColorAngel of Deth Custom Graphic
Case OptionsHardshell Case Included
esp ltd iron cross:
Construction
Set-Neck
Scale
24.75"
Body
Mahogany
Top
Maple
Neck
Mahogany
Fingerboard
Ebony
Fingerboard Radius
350mm
Finish
Snow White w/ Stripes Graphic
Nut Width
42mm
Nut Type
Molded
Neck Contour
Thin U
Frets/Type
22 XJ
Hardware Color
Black
Strap Button
Standard
Tuners
LTD Locking
Bridge
Tonepros Locking TOM Bridge & Tailpiece
Neck PU
EMG JH SET
Bridge PU
EMG JH SET
Electronics
Active
Electronics Layout
Vol/Vol/Tone/Toggle Switch
Case
CECFF
Case Included
solo quiero sus opiniones y cual les parece mejor ya que para mi es solo para decidirme.
saludos
TopMahogany
BodyMahogany
NeckMahogany
Scale Length25 1/2"
FingerboardEbony
# of Frets24
KnobsBlack Dome
Hardware ColorBlack
BridgeTune-O-Matic
FinishGloss
esp ltd iron cross:
Construction
Set-Neck
Scale
24.75"
Body
Mahogany
Top
Maple
Neck
Mahogany
Fingerboard
Ebony
Fingerboard Radius
350mm
Finish
Nut Width
42mm
Nut Type
Molded
Neck Contour
Thin U
Frets/Type
22 XJ
Hardware Color
Black
Strap Button
Standard
Tuners
LTD Locking
Bridge
Neck PU
EMG JH SET
Bridge PU
EMG JH SET
Electronics
Active
Electronics Layout
Case
CECFF
Case Included
saludos
