dicen que en 30 dias te devuelven tu dinero si no te gustan,yo he comprado el triple pack,lo he desinstalado del monkey y voy a la pagina de retun para devolver la licencia y mirad lo que me dice:
That was not a valid License Key
From your account page, you can view the License Keys you have purchased. Copy the License Key you want to return from there, and paste it here. Your License Key is also found in the email we sent to confirm your purchase, and you can copy it from there to paste in below. If you continue to be unable to initiate your return, please go to line6.com/support to access our online knowledge base and support e-mail system and contact our support staff.
Returning A License Key Purchase
You may return a Line 6 License Key on this page within 30 days of the order date and automatically receive a full refund to your credit card, except for orders that also contain an "iLok License" which cannot be returned as stated in the Line 6 ***** Return Policy.
If your order contains multiple items, then all items in that order will be returned together if you complete the return using this page. Any items you purchased in separate transactions will not be returned. If you have already activated the item(s) in your Line 6 hardware, you must run the Line 6 Monkey software with an active Internet connection to complete the return and receive a credit.
To begin the return process, enter your Line 6 License Key Number for the order that you would like to return. This number was emailed to you after your purchase, and it can also be found in your account.
la licencia que le meto es la misma que utilizo para activarlo con el monkey,una que contiene un monton de numeros que me llego asi:
Order Items:
Line 6 License keys: ( For Line 6 compatible hardware )
20A8260V99XB9195E7B69C4401AY2Z49
¿se supone que la misma clave que se usa para activar con el monkey hay que introducirla en la pagina esta despues de haberlo desinstalado con el monkey no?
Line 6 Error Page (cambiar el cero por una o)
¿alguien sabe algun correo electronico donde pueda ponerme en contacto con ellos o decirme si algo lo estoy haciendo mal?
¿o quizas esta gente se niega a devolverme mi dinero?
si no me lo devuelven me estan engañando evidentemente,pues en la pagina dicen bien clarito que tienes 30 dias para devolver los model pack
