He mirado por ahi pero no he visto nada sobre el tema
Tuve una averia en POD xt Live y he perdido los models packs
Alguien los ha reinstalados una vez de perdidos
Ya tengo las contraseñas y todo pero nada, no lo consigo
Sigo las instrucciones pero nada.
Mas o menos lo que dicen es esto
Go to Line 6
Your License Keys are listed there. Find the License Key you want to transfer and click its [Transfer] button. Note: you can only transfer one license key at a time.
Connect via USB the Line 6 hardware the License Key was activated in. Run Line 6 Monkey.
Click the [Transfer] Button in Line 6 Monkey and follow its directions. This will deactivate the License Key from your hardware, so those Optional Add-Ons will no longer function.
Quit Line 6 Monkey and disconnect the device you have just deactivated. You can see at Line 6 that the License Key now shows as uninstalled.
Ready to activate that License Key in another piece of compatible Line 6 hardware? Connect that hardware via USB and run Line 6 Monkey.
From Line 6, copy the License Key you want to activate (the one you're transferring).
Click the [Activate Purchase...] button in Line 6 Monkey, paste in the License Key (or type it in exactly as shown on Line 6 ) and click [OK]
Follow the directions from Line 6 Monkey, and start enjoying your Optional Add-Ons in their new home!
The Line 6 store policy gives more info on License Key transfers: Line 6
Pero cuando llego al Click the [Transfer] Button in Line 6 Monkey, donde coño está ese boton en el Line 6 monkey
