The SW amps are tilt-back style practice amps. Three types of SW amps are provided: for players looking for a big sound, players looking for a small amp that has the same number of functions as higher-grade amps, and players looking for the biggest speaker possible at the lowest possible price. With a tilt-back design that aligns the amp at just the right angle with your standing position and with the Limiter that provides precise control to prevent unfavorable distortion, SW amps are truly worthy of being called the absolutely best practice amps.
Output: 80W @ 4 Ohm
Speaker: 15' Speaker with Piezo Tweeter
Controls: Gain, Bass, Low-Middle, High-Middle, Treble, Volume, Compression Switch, Shape Switch, Roll off Switch, Distortion Switch (Footswitchable), Envelope Filter Switch (Footswitchable)
i/o's: Input, Aux Input, Line Out, Headphones Out, Footswitch Jack
Cabinet: Tilt-back, ported
Size (mm): 540(W) x 400(D) x 550(H)
Size (inch): 21.3'(W) x 15.7'(D) x 21.7'(H)
Weight: 20.2kg (44.6lbs)
También me gustaría saber si los 80 W son RMS, o sea, la calidad REAL de POTENCIA que me puede dar el amplificador.
Muchas Gracias de antemano. EziiTo.
