Ayuda sobre Marshall vs100 valvestate
-18%Fender Standard Strat LRL WPG AMM
-20%tc electronic Hall of Fame 2
-10%Epiphone Kirk Hammett 1979 Flying V
Sacado del manual:
For connection to external loudspeakers. The
minimum operating impedance for the VS100R, VS100H
& VS102R is 4 Ohms. The internal speaker on the
VS100R/VS102R is rated at 8 Ohms, therefore if using an
external speaker in conjunction with the internal speaker,
the external speaker should be rated at 8 Ohms.
Está mas que claro... se puede siempre que sea de 8 ohm la pantalla que le pongas.
