Ayuda con mi ampli de bulbos
-45%Hughes & Kettner Spirit of Rock
-45%Hughes&Kettner Spirit of Metal
-11%Harley Benton HBD120CEBK Bundle
Con válvulas de potencia como las 6l6 tienes que vigilar cuando las cambias porque normalmente al cambiar válvulas de potencia hay que ajustar la Bias. Hay amplis que ya no necesitan ese ajuste, infórmate de si el tuyo es así.
Y ante la duda de las válvulas, investiga en google y si no pregunta directamente a Peavy,
¿por qué no?
¿por qué no?
A ver si esto te sirve:
"6L6GC types Most needed for guitar amps but these make a fine hi-fi tube in any amp calling for a KT66, 7581, or even 5881. The blackplate RCA are the stars, and rightly so. They are rich, warm, detailed, creamy, and powerful. No other tube comes close except possibly the NOS GE 6L6GC. The GE is a bit more linear from top to bottom and lacks some of the RCA richness, but we are still talking about the two best NOS tubes in this class! The GE is often much less costly, but this may change as they become scarce. Sylvania made this tube for many other brands. They are typically bright and sparkly, if a bit leaner in the bass. Usually the Sylvania made NOS tube is the winner when it comes to bargain performance. Do not overlook some of the current production tubes. The few that deserve attention are the JJ from the Slovak Republic, and the Winged C from SED, St. Petersburg, Russia. Both have near-NOS sonics at a much lower price. The 6L6GC type can substitute for any of the types below, but may require a bias adjustment or modification to operate at peak performance. Consult an amp tech whenever substituting tube types."
Yo creo que no tendrías que tener problemas. Sencillamente me da la sensación de que una válvula tiene unas características sonoras y la otra es un poco distinta, pero supongo que a nivel técnico no tendrías que tener problema.
Otro tema es si al cambiar las válvulas tienes que hacer el ajuste de bías. Antes había que hacerlo siempre, ahora hay algunos amplis que ya no lo necesitan, pero es importante estar seguro.
Pues como ya te dijeron, no debes tener problema entre los tipos de bulbos, hace mucho los fabricantes les agregaban alguna letra simplemente para diferenciar algun parametro y tener preferencia del consumidor.
hay dos tipos de configuraciones de amplis, los de bias fijo y los de bias de catodo, estos ultimos no requieren ajuste de bias, los otros es importante hacerlo, pue smuy bajo el bias, sonara feo, y demasiado bias te acabas los bulbos de salida en un santiamen, hay veces que este conrol de bias no es accesible desde afuera.
vigila que nunca se pongan rojas las placas, checa el manual
espero esto te sirva
saludos
Alex
saludos
Alex
