DIFERENCIAS DE AMPLIFICADORES CLASS A Y CLASS A/B
vidaljuanes
por el 31/08/2012
Hola a todos, considere interesante el ariculo en la hoja de los Ampli Soldano
Class A and Class A/B are terms that describe how the power tubes work within the power section of a guitar amplifier. To properly explain the technical differences between these classes of operation would require a lengthy discussion. However, in short, the differences can be summarized as follows:
Class A/B amps tend to have greater dynamics, sound punchier, tighter, cleaner, and have cooler running tubes. The Class A amp sounds more vintage and squishy, because it’s compressing and distorting more. Tubes in a Class A amp tend to run hotter, as well. For the same given tube compliment, Class A/B will produce two-to-three times as much power as Class A. An example would be an amplifier with two 6L6s in the power section. Operating in Class A, the maximum power we could expect would be around 20 watts, while operating in Class A/B would easily yield 50 watts.
Just for tube life alone, I believe Class A/B is the way to design any amp. The amp will run more efficiently with more power and you’ll enjoy not having to replace power tubes as often. If the tonal characteristics of a Class A are desired, an A/B amp can be carefully designed to do that (the Soldano Astroverb is a good example of such a design).
Traducción:
Clase A y Clase A / B son términos que describen cómo funcionan las válvulas de potencia dentro de la etapa de potencia de un amplificador de guitarra. Para explicar adecuadamente las diferencias técnicas entre estas clases de operación requeriría una larga discusión. Sin embargo, en resumen, las diferencias pueden resumirse como sigue:
Los amplificadores de clase A / B tienden a tener una mayor dinámica, el sonido con más pegada, más fuerte, más limpia, más frescos y tienen tubos de funcionamiento. La clase A amplificador suena más vintage y blando, porque está comprimiendo y más distorsionantes. Tubos en un amplificador de clase A tienden a calentarse más, también. Para el mismo cumplido dado tubo, Clase A / B se producen de dos a tres veces tanta energía como de Clase A. Un ejemplo sería un amplificador con dos 6L6s en la sección de potencia. Con operaciones en Clase A, la potencia máxima que podríamos esperar sería de alrededor de 20 vatios, mientras que en Clase A / B fácilmente producir 50 vatios.
Sólo por la vida del tubo solo, creo que la clase A / B es la forma de diseño de cualquier amplificador. El amplificador funcionará más eficazmente con más energía y podrá disfrutar de no tener que reemplazar válvulas de potencia con tanta frecuencia. Si las características tonales de Clase A se desea, un amplificador A / B puede ser cuidadosamente diseñado para hacer que (el Astroverb Soldano es un buen ejemplo de este tipo de diseño).
http://www.soldano.com/amp-help/class-a-vs-class-ab-guitar-amplifiers/
:leyendo:
    166 €
  • -23%
    TC Electronic Ditto Looper
    59 €
  • -50%
    ESP LTD M-200 STBLK
    333 €
aguesk
por el 31/08/2012
Te pongo dos enlaces para que los leas, que te puede venir bien para aclarar tus dudas:
- Clase A: http://www.lafuentedelsonido.com/contenido/amplificadores-de-clase
- Clase A/B: http://www.lafuentedelsonido.com/contenido/amplificadores-de-clase-b-y-ab
vidaljuanes
por el 01/09/2012
Gracias #2 , super buena la información.
:aplausos:
