bueno tambien les recuerdo que tengo el Pod HD500. Favor sus comentarios para ver cual seria mi mejor opción.
adjunto las caracteristicas principales de las 3 maquinonas.
DT50
Advanced HD modeling technology
Reinhold Bogner’s most flexible tube design
(2) 12AX7 preamp, (2) EL34 power amp (25W/50W)
Simple and straightforward 2-channel design
Each channel: Drive, Bass, Mid, Treble, Presence, Reverb, Channel Volume
Master volume
High and Low inputs
Reconfigurable analog components (Class A/Class AB; Pentode/Triode)
Complete, one-touch analog reconfiguration (via Channel select switch)
Low-power mode
MIDI in and out
L6 LINK™ in/thru connection for POD® HD integration
Footswitch jack for channel switching
Serial effect loop with level control
XLR direct out with cabinet simulation and ground lift switch
4, 8 and 16-ohm speaker outs
Series One 1046L6
100W Watt head with built-in DPR power reduction
4 x ECC83, 1 x ECC82, 4 x 6L6 valves
4 switchable channels
Clean channel with Warm (Plexi) and Bright (Class A) type modes
Crunch channel with Crunch and Super Crunch modes
Two overdrive channels with high and low output damping
Two ISF equipped tone control sections
Presence and resonance controls
Master Volume
Series effects loop
MIDI switching
Speaker emulated output
Tourmaster 4100
100-Watt All-Tube Head
Premium Tubes:
8 x ECC83S
4 x 6L6
Four Channels with Selectable Voicing
Power Grid: Set Wattage for Each Channel from 10w to 100w
Tube-Driven Assignable Effects Loop
Tube-Driven Reverb
Rugged Six-Button Footswitch FRONT PANEL
Four Independent Channels Each With:
Gain Control
Master Control
Treble, Middle, Bass
Classic/Modern Voicing Switch
Tube-Driven Reverb
Master Presence/Density REAR PANEL
Assignable Tube-Driven Effects Loop
Assign to Channels 1 & 2
Assign to Channels 3 & 4
Assign to all Four Channels
Assign to Pedal Only
Send and Return Level Controls
Selectable Series or Parallel
Cabinet Voiced Line/Recording Out
Simple Master Bias Adjust with Test Points
Dimensions: 27.5" (L) x 11" (W) x 10" (H)
Weight: 60lbs
desde ya gracias
