ENGL Fireball 100 vs Mesa Dual rectifier
blackmetalarg Baneado
por el 12/05/2012
Engl E625 Fireball
[ Imagen no disponible ]
Preamp:
2 channels, Clean, Lead, 3 band EQ, Bright switch, Depth switch, Presence control, 3x ECC83 preamp tubes.
Master Section:
Master A/B, 60 watts (1 x ECC83, 2 x 6L6GC power amp tubes).
Outputs:
Speaker Outs (2 x 8, 2 x 16 Ohms), fx loop, (parallel to serial adjustable), dual footswitch jacks (Z-3 or Z-4).
Dimensions & Weight:
71 x 27 x 27 cm, 19 kg
Mesa Boogie Dual Rectifier
http://www.espacemusical.fr/images/Image/ampli-guitare/mesa-boogie-dual-rectifier-amplis-tetes-guitare-p5924_1.jpg
Multi-Watt™, Channel Assignable Power Amp (Patent 7,602,927) allows you to assign either 2 or all 4 Power Tubes to each Channel for Power Ratings of 50 or 100 Watts of Class A/B Power via independent 50/100 Watt Power Switches / 4x6L6 (or 4xEL-34), 5x12AX7, 2x5U4
Bias Select Switch (6L6/EL34) • Fixed Bias for Consistent, Maintenance Free Performance
3 Fully Independent Channels with 8 modes (Channel 1 = Clean or Pushed, Channel 2 & Channel 3 = Raw, Vintage High Gain or Modern High Gain)
Each Channel features: Multi-Watt Power Switch (50/100 Watt), Independent Gain, Treble, Mid, Bass, Presence, Master, Channel Assignable Dual Rectification with Recto Tracking™ (Diode or Tube Tracking – Patents 5,168,438 & 7,193,458)
Footswitchable or Completely Bypass-able Fully Buffered FX Loop with Send Level Control
Output Level Control (over all channels when activated)
Footswitchable Solo Level Control (Patent 6,724,897 - over all channels when activated)
Bold/Spongy “Variac” Switch (Patent 5,091,700)
True “Hard” Bypass Switch that removes FX Loop, Output Level & Solo Level Controls from signal path
Tuner Output w/Footswitchable Mute
Slave Out w/Level Control
External Switching Jacks for Channels 2, 3 (Ch 1 is default), Solo & FX Loop
New 3x3 - 6 Button Footswitch (Bottom Row: Channel 1, Channel 2, Channel 3, Top Row: Tuner Mute, FX Loop & Solo)
Slip Cover
Head (Width 25 1/2”)
  • -50%
    ESP LTD M-200 STBLK
    333 €
skamot
por el 12/05/2012
Esto es una consulta ? ,, pregunto .... xD
hellvilleRock
por el 12/05/2012
Dos bichacos, sin duda, pero el Mesa se lo lleva de calle, si lo que quieres es compararlos.
ludox
por el 13/05/2012
Yo he tenido el engl Fireball 60 y mi compañero en ese tiempo tenia el mesa single rectifer y son amplificadores totalmente diferentes , se que no es lo mismo que el dual y que el Fireball 100 pero son bastante parecidos.
En primer lugar el rectifier es muchisimo mas versatil tiene mucha mas pegada y es mas dificil de equalizar para estar contento con el sonido , es mucho mas dificil de tocar , como que tienes que sufrir un poco para sacarle el sonido , tienes que esforzarte mas en la ejecucion.
El fireball no cuesta nada equalizarlo y es muy comodo de tocar suena bien siempre , es menos versatil , yo no le encontraba sonido crunch por ningun lado o limpio o caña , tiene el triple de gain que el rectifier no necesitas pedales para hacer chillar tu guitarra en plan armonicos y la distorsion es mas densa con menos grano.
Tienen sonidos tan diferentes que es muy complicao decir cual es mejor el sigle muchas veces me sonaba chicharrero hay que hacertar muy bien con la equalizacion i el fireball me sonaba barullero con grabes fofos muchas veces.
elmontu
por el 03/11/2012
Me interesa la opinión de Skamot y Ludox!
Estoy en un dilema para una caja 4x12 mis opciones son:
ENGL 4x12 Standard Slanted
Mesa Boogie 4x12 Traditional Slant
El ampli es un Fireball 100 que actualmente uso con un Mesa Boogie 2x12 Vertical Slant.
