Pedal para sonar como Nirvana.
jorgebz
#1 por jorgebz el 29/06/2008
Hola a todos
Quisiera que me dijerais que pedal o pedales tendria que usar para sonar como Nirvana en canciones como Smells like teen spirit, Rape me, Territorial Pissings... ya que en mi grupo las tocamos y el sonido no me acaba de convencer del todo
sin mas, un saludo, y gracias anticipadas a todos aquellos que aporten algo al tema
    PRS SE CE 24 BR
    633 €
  • -50%
    Epiphone Dave Grohl DG-335 Pelham Blue
  • Millenium Rookie E-Drum Set
    189 €
eha
#2 por eha el 29/06/2008
Si sabes ingles mejor, sino dime y lo traduzco:
" The release of Nirvana's Nevermind and In Utero albums reintroduced guitarists to the sonic capabilities of Electro-Harmonix's lesser known effects pedals, including the SmallClone and PolyChorus. Guitar rigs stocked full of rack mounted delays and digital distortion units suddenly became unfashionable (as did spandex-clad guitarists). Whether you're a cover band playing weekend gigs, a basement jam band, or simply a PedalNut like us, it is virtually impossible to replicate Kurt Cobain's tone on Nevermind without adding the following effects to your pedalboard:
Boss DS-2 Turbo Distortion - standard Boss pedal casing and three knob configuration (level, tone, distortion), with the added bonus of a turbo knob. Set the tone and distortion knobs near the maximum, and turn the turbo knob to "II" to zone in on Cobain's tone. Used DS-2 pedals are readily available on Ebay.com and craigslist.com for about $50.00. New pedals go for $90.00 (presently as low as $40.00 at Musicians Friend). While the DS-2 distortion is known to have been a mainstay of Cobain's pedalboard (look closely at the photographs in the In Utero liner notes), also consider buying the Electro-Harmonix Big Muff pedal which provides dirtier distortion at lower volumes;
Electro-Harmonix SmallClone - a must-buy pedal if you're planning on playing "Smells Like Teen Spirit" or "Come as You Are" for an audience of more than three people (your parents and significant other excluded). Set the rate knob at the 3 o'clock position and slide the depth switch down to experience the rapid, yet deep, chorus preferred by Kurt Cobain. If you're lucky, you'll find a vintage version of this pedal on Ebay.com, but not for less than $150.00. Vintage SmallClone's are widely considered to be more expressive, but are less reliable than the re-issue pedals from Electro-Harmonix. Also, vintage SmallClones surviving the Punk, post-Punk, and New Wave eras smell awful (and certainly nothing like teen spirit).
If you want to take your Nevermind-inspired playing to the next level, pick up a rack-mounted Mesa/Boogie Studio preamp, a Crest 4801 power amp (or two depending on your budget), and a Marshall 4x12 cabinet. Tweak the settings on the Mesa Boogie Studio preamp to dial in on the right tone, but be sure to use the clean channel with the midrange set quite high."
jorgebz
#3 por jorgebz el 29/06/2008
si es en español mucho mejor:brindis:
gracias!!!
dani16
#4 por dani16 el 29/06/2008
año 1992:
año 1993:
año 1994:
Mas informacion:
PEDALES
1.Distorción Boss DS-1. Caja fundamental para los primeros años, referida por Kurt como Roland EF-1.
2.Electro-Harmonix BigMuff. Supuestamente usada para Nevermind. (No se le vio con uno de estos nunca)
3.ProCo Rat. Usada para Nevermind. (Posiblemente solo usado por Krist en Breed y en Turnaround)
4.Boss DS-2. (Remplazo al DS-1 en la gira del Nevermind por Europa)
5.Electro-Harmonix Small Clone, coro.
6.Electro-Harmonix Polychorus. Cuatro modos: Flanger, Chorus, Double Tracking, y Filter Matrix
7.Electro-Harmonix Echoflanger. Igual al Polychorus.
8.Tech 21 Sansamp. en la gira de In Utero fue la distorcion principal (en el "Live & Loud" se ve claramente).
9.DOD, pedal de Grunge. (}Usado a manera de broma y arrojado al publico en la gira del In Utero)
10 Pedal Wah desconocido usado para grabar Love Buzz
AMPLIFICADORES
1 Mesa Boogie pre amp
2 Gabinetes Marshal 4x12
3 Fender twin reverb (Usado para grabaciones y como monitor en el Unplugged)
VARIOS
Puas Dunlop tortex 60 mm (las naranjas)
Microfonos Shure
Cuerdas Dean Markley calibre 9
comatorium
#5 por comatorium el 29/06/2008
no sea flojo y aprenda ingles :D pues basicamente dice qeu los pedales qeu usa el mugroso ese son el ds-2 y lo usa masomenos por la distorcion y tono a tope y el modod II, y el small lo usa para cnaciones como come as you are y smell y que se ponga masomenos por las 3 para que suene a como el lo tenia
jorgebz
#6 por jorgebz el 03/07/2008
todo claro, muchisimas gracias a los dos y bien es verdad que una imagen vale mas que 1000 palabras :brindis:
adri_rock92
#7 por adri_rock92 el 01/11/2008
q efectos son los q se usan en el pedal para sonar como smell like teden spirit??:|
carls501
#8 por carls501 el 01/11/2008
efectos para esa cancion... pocos ¿no? lo que mas escucho es la distorsion pura y dura, y un poquito de delay en ciertos momentos, no?
dani16
#9 por dani16 el 01/11/2008
chorus para el solo, Cobain usando delay?? yo creo que cobain pasaba de delays
freak_insane
#10 por freak_insane el 03/11/2008
sencillo
chorus
ds1
ds2
con eso tienes todo
delays???????????????????'
no
saludos
diegopg
#11 por diegopg el 03/11/2008
mmmm , para tocar Nirvana creo que un pedal de JB o simplemente a birras ya te vale :D
Ahora enserio , quiza un muff?
lasm2000
#12 por lasm2000 el 03/11/2008
La forma más economica que reproduzcas ese sonido es con el pedal grunge de dod. Deberia ser fácil de conseguir, no es el mismo equipo que usaba nirvana pero a mi modo de ver es mejor para reproducir esos sonidos pues tampoco tienes el mismo ampli que ellos usaban, ese pedal esta diseñado para dar ese tipo de sonidos en casi cualquier setup. Algun chorus seria util, tal vez tu amplificador ya lo tenga.
Otro plan seria que te consigas un Behringer V-Amp o un POD, por curiosidad baje unos tonos de internet ahora que vi tu mensaje y reproducen muy bien ese sonido.
