No hay nada confirmado aún por LINE6 peeeeero me parece que nos vamos a morir de envidia, y personalmente creo q voy a ir poniendo en venta ya mi XT live...
[ Imagen no disponible ]
Why change from PODxt?
The POD X3 live one offers innumerable new functions, with which one can work still by far more creatively and lend to its music still much more expression.
• the POD X3 live one contains more amplifier, box and effect models than the other devices of the POD® series. The proof: 78 amplifier and 24 box models for guitar, 98 effects, 28 amplifier and 22 box models for bass as well as 6 models of Mic Pre amps.
• Also the basing aster and remaining control elements of this soil unit make an extremely solid impression. A swelling pedal (Wah/volume/Expression) in the racing car Design.
• Work on your guitar simultaneously with two complete guitar Rigs, in order to inspire your public with an impressive “sound barrier”.
• The by far larger display indicates the complete signal path of both chains. The amplifier and effect parameter can be edited now on a side. Thus one saves time.
• Also your acoustic guitar, a bass and even singing can be captured now with the POD Soundmagie....
• Simultaneous use of the XLR and 1/4” - entrance for two signal sources with separate treatment - ideal in the Studio and live.
• USB 2.0-Port for multi-trace photographs with all usual photograph programs. If necessary you can at the same time take up even the “dry” and a Stereoversion of the worked on signal, in order to remain flexible up to merging.
• The digital S/P DIF exit can be used for the connection with a pro Tools system or other Studiogear.
+ Info y caracteristicas (sin confirmar): http://www.vettaville.nl/vvpodx3.html
