Hola, estas son las especificaciones:
The PA2 is a straight booster preamplifier mounted on a minitoggle switch. Perfect if you want to just plain overdrive the input of your amp for distortion. It has a trim pot so you can preset the amount of boost up to an additional 20 dB. The PA2 will also work with passive pickups.
Package Includes: Output jack and battery clip set.
EMG PA2 Preamp Booster Switch Specifications:
* Input Impedance (Ohms): 500K
* Output Noise@ 60Hz: -91 dbV
* Output Noise (Spectral): 130 dbV (-110 dbV @ Full Boost
* Output Impedance (Ohms): 2K
* Current@ 9V (Microamps): 290
* Battery Life (Hours): 1725
* Maximum Supply (Volts DC): 27
Simplemente se trata de un booster con un amplificador operacional y 20 db. de ganancia montado en una placa con un switch, es como cualquier booster que puedas encontrar en GGG por ejemplo el mxr microamp.
