Tom hess, como tocar mas rapido?
maximili
por el 11/05/2009
hola muchachos, navegando en la red consegui esto, y necesito ayuda, primero para traducirlo y segundo para conocer que opinan uds de lo que dice alli,( mas o menos por encima se que es para tocar mas rapido )de antemano gracias. A continuacion el texto en ingles
The scope of this subject is too broad to be fully covered in a single article. After receiving hundreds of requests for advice on this subject of developing speed, it seems an article is long overdue on the topic. Training advanced players to become virtuosos is a very rewarding and fun process for me. (as I'm sure it is for most teachers who teach highly advanced students).
A Typical question from a student: What specific strategy should I employ to approach better speed development?
Although my answer varies from person to person, depending on what I know about that person's current abilities and goals (among other things), I generally recommend some variation of the following strategy:
Stage 1: When first learning a new technique, determine (using a metronome of course) your maximum speed you can play cleanly. Write this speed down on paper in a practice log.
Stage 2: Practice at 20%-35% of your maximum speed. Do this for 5 consecutive practice sessions. Resist the temptation to go faster during this stage. Make sure everything is still very clean. There must be NO excessive tension anywhere in your arms, hands, wrists, shoulders, neck, head or anywhere else. Watch to make sure you have no excessive or unnecessary movements in either hand. For some guitarists, this first step is very boring. You MUST remain patient with yourself, and the process, during this time. This is absolutely critical! If you skip this step, you will probably train your hands to play incorrectly, inefficiently and ineffectively. At this stage you are developing the proper muscle memory for this technique. If you are currently studying with a great guitar teacher, your progress will be much faster, easier and better than if you attempt to do this on your own. Once you have mastered stage two, you may move on to stage three, but not before! Above I said you should practice this stage for 5 consecutive practice sessions. That is only a general guideline, after the 5th session, reevaluate your progress. If you have not mastered this step, continue practicing at 20%-35% before moving on to stage 3.
Stage 3: Practice at 50% of your maximum speed. Do this for 3 consecutive practice sessions. Again, make sure everything remains very clean. Play relaxed without tension anywhere in your arms, hands, wrists, shoulders, neck, etc. Watch to make sure you have no excessive or unnecessary movements in either hand. Do not move on until this step is mastered (it could take longer than 3 sessions, but do NOT move on to stage 4 before practicing for 3 sessions.
Stage 4: Practice at 60-65% of your maximum speed. Do this for 3 consecutive practice sessions. Again, with total relaxation and economy of motion (no unnecessary movements).
Stage 5: Practice at 80% of your maximum speed. Do this for 5 consecutive practice sessions.
Stage 6: Practice at 85% of your maximum speed for the next (1) practice session only.
Stage 7: Practice at 90% of your maximum speed for the next 10 practice sessions.
Stage 8: DRILL IT! TOTALLY RIPPIN (translation play at 100%) FOR an entire week!
Stage 9: After that week evaluate where your new maximum speed is (it will be higher than when you first measured it in stage 1).
Stage 10: In this stage you will rotate every 3 practice sessions like this: Session 1 = 60%. Session 2 = 85%. Session 3 = 95%. At the end of each practice session DRILL IT (100%) for a few minutes.
Once a week, measure your new maximum speed, and adjust your metronome speeds accordingly.
Warning: NEVER play/practice your guitar in pain. Serious injuries can occur. This is not a joke, I know people personally that have had to have surgeries on their wrists and arms!
    102 €
    482 €
leviatan_soul999
por el 12/05/2009
Es basicamente una rutina de como tocar rapido... Se basa en determinar tu velocidad maxima, despues practicas en proporciones mas bajas de esa velocidad por un tiempo y despues practicar al maximo de tus capacidades musculares... En teoria es como lo que hacen los corredores de pista... Creo que independiente de la tecnica que comparte lo mas rescatable es esto
"Si actualmente estas estudiando con un gran maestro de guitarra, tu progreso sera mas rapido, facil y mejor que si intentas esto por tu cuenta".
Por eso la importancia de buscar al maestro mas competente que podamos.
En si la tecnica es buena y tiene algo que ver con las barreras psicologicas...
Buen articulo, en geral todos los que escirbe son buenos, los de sus alumnos tambien. Ademas Tom es un gran maestro yo estudio en su programa de improvisacion y actualmente estoy en su circulo elite de maestros de guitarra....
sirvampiria
por el 22/05/2009
El alcance de este tema es demasiado amplia para ser plenamente cubiertos en un único artículo. Después de recibir cientos de solicitudes de asesoramiento sobre este tema de desarrollo de velocidad, parece un artículo hace tiempo sobre el tema. Formación avanzada a los jugadores convertirse en virtuosos es un proceso divertido y gratificante para mí. (como estoy seguro de que es para la mayoría de los docentes que enseñan a los estudiantes muy avanzados).
Una típica pregunta de un estudiante: ¿Qué estrategia debo utilizar para una mejor velocidad de enfoque de desarrollo?
Aunque mi respuesta varía de persona a persona, dependiendo de lo que sé acerca de esa persona en la actualidad las capacidades y las metas (entre otras cosas), me suele recomendar alguna variación de la siguiente estrategia:
Etapa 1: Cuando primero aprender una nueva técnica, determinar (mediante un metrónomo por supuesto) su velocidad máxima que puede jugar limpiamente. Esta velocidad de escritura sobre el papel en una práctica de registro.
Etapa 2: Práctica en el 20% -35% de su máxima velocidad. Haga esto por 5 sesiones de práctica consecutivos. Resistir la tentación de ir más rápido en esta etapa. Asegúrese de que todo es aún muy limpio. No debe haber exceso de tensión en cualquier lugar de sus brazos, manos, muñecas, hombros, cuello, cabeza o cualquier otro lugar. Mira para asegurarse de que no tienen los movimientos excesivos o innecesarios, ya sea en mano. Para algunos guitarristas, este primer paso es muy aburrido. Usted debe seguir siendo paciente con usted mismo, y el proceso, durante este tiempo. Esto es absolutamente crítico! Si omites este paso, es probable que las manos de tren para jugar mal, ineficiente e ineficaz. En esta etapa se están desarrollando la memoria muscular adecuado para esta técnica. Si actualmente está estudiando con un gran profesor de guitarra, su progreso será mucho más rápido, más fácil y mejor que si se intenta hacerlo por su cuenta. Una vez que haya dominado fase dos, puede pasar a la tercera fase, pero no antes! Anteriormente he dicho que deben practicar esta etapa consecutivos durante 5 sesiones de práctica. Esto es sólo una guía general, después de la 5 ª sesión, reevaluar su progreso. Si usted no ha dominado este paso, seguir con la práctica en el 20% -35% antes de pasar a la fase 3.
Etapa 3: Prácticas en el 50% de su máxima velocidad. Haga esto durante 3 sesiones de práctica. De nuevo, asegúrese de que todo está muy limpio. Juega en cualquier lugar relajado, sin tensión en sus brazos, manos, muñecas, hombros, cuello, etc Mira para asegurarse de que no tienen los movimientos excesivos o innecesarios, ya sea en mano. No se mueva hasta que este paso es dominado (que puede tardar más de 3 sesiones, pero no pasar a la fase 4 antes de practicar durante 3 períodos de sesiones.
Etapa 4: Práctica en el 60-65% de su máxima velocidad. Haga esto durante 3 sesiones de práctica. Una vez más, con la relajación total y la economía de movimiento (sin movimientos innecesarios).
Etapa 5: La práctica en el 80% de su máxima velocidad. Haga esto por 5 sesiones de práctica consecutivos.
Etapa 6: Prácticas en el 85% de su velocidad máxima para el próximo (1) período de sesiones la práctica solamente.
Etapa 7: Práctica en el 90% de su velocidad máxima para los próximos 10 sesiones de práctica.
Etapa 8: PERFORACIÓN TI! TOTALMENTE rippin (traducción jugar al 100%) para toda una semana!
Etapa 9: Después de evaluar durante la semana, donde la nueva velocidad máxima es (será mayor que la primera vez que se medirá en la etapa 1).
Etapa 10: En esta etapa se rotan cada 3 sesiones de práctica de esta manera: Sesión 1 = 60%. Sesión 2 = 85%. Sesión 3 = 95%. Al final de cada período de sesiones la práctica PERFORACIÓN TI (100%) durante unos minutos.
Una vez a la semana, medida de su nueva velocidad máxima, y ajustar en consecuencia su velocidad de metrónomo.
Advertencia: Nunca juegues / práctica de la guitarra en su dolor. Lesiones graves pueden ocurrir. Esto no es una broma, sé personalmente personas que han tenido cirugías para tener en sus muñecas y brazos!
:DESTE ES MI PRIMER POST ESPERO LES GUSTE AHI TENGO MUCHA COSA SOBRE GUITARRA TENGO 3 GRUPOS DE METAL Y SOY GUITARRA LEAD ME VA ALGO QUEDADO CON ACORDES ES DECIR LOS SE PERO EL CAMBIO DE ACORDE ME DA DURO AJJA GRAXX
SIRVAMPIRIA
ANTONY SOTO:cool:
metalllater
por el 12/10/2009
En qué consistiría una sesion como aqui la llaman? de que ejercicios se compondria? cuanto tiempo? ...en definitiva: como seria una sesion "tipo"?
Me ha gustado mucho el articulo, me encanta la objetividad!!
Fher_84
por el 12/10/2009
Puedes buscar el programa Guitar speed trainer, en el que primero desarrollas un perfil de velocidad en distintos niveles, como en una cuerda, dos cuerdas,cromaticos, escalas, modos y punteo al azar y basicamente por decirlo asi te crea un programa de entrenamiento con ejercicios que aumentan de tempo en cada repetición.
Tratare de subir el programa en a seccion de descargas.
metalllater
por el 12/10/2009
ok, muchas gracias!!
yooorch
por el 10/02/2011
oye cuando los guitarristas tocan asi bien rapido tiene un nombre comose llamaba
onda asi como jimmy hendrix
por fa recuerdenme
